FEL bucket tilt
/ FEL bucket tilt #1
sos1
Does anyone know the stroke length needed to operate a 15"x15"x 36"
bucket using the shortest stroke practical. The cylinder I have has a 7 1/2"
stroke. I've looked at different linkages to increase the distance moved but
I'd prefer to just have a direct connection if possible.
/ FEL bucket tilt #2
The closer the push point to the base line or hinge, the shorter the stroke, and a faster curl. Stroke could be very small. The more separated those points, the slower the curl, but more force is realized.
If you have to use that particular cyl, just attach it to the base, and rotate the bucket for the amount of curl you want and then weld on some mounting lugs..
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
Caterpillar D5M and D5M LGP Dozer Service and Parts Manuals (A63117)
Caterpillar D5M...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
UNUSED IREV HIGH END TWO-WHEELED ELECTRIC VEHICLE (A64281)
UNUSED IREV HIGH...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
