Fatal Tractor Rollover
/ Fatal Tractor Rollover #31
I still groan after all these years when a young life is lost. Please use your seatbelts and ROPS.
/ Fatal Tractor Rollover #34
My guess the mower was lifted and he ran off the Rd. The weight offset the Front end and the kid lost control. JMO The blades are lifted so he wasn't using the mower at the time and the grass reflects that. Educate Your opinion that was mine. Didn't read yours.
/ Fatal Tractor Rollover #36
Another good resource to text to your family and friends during this season
/ Fatal Tractor Rollover #37
What happens in a lot of rollover fatalities, either car or equipment, is not that the driver is thrown totally clear of the vehicle and then rolled onto but rather partially ejected from the side window and then rolled onto. The flopping action of the vehicle tosses the occupant sideways and partly out the window. You don't know for sure exactly what happened but this from a friend that has dealt with a lot of rollovers.
Such a tragic accident.
Each accident is different. What seems to be the common theme is that it happens quicker than one expects, whether it is a tractor rolling onto its side, turning turtle, or flipping over the rear end.
Without ROPS, if the tractor turns turtle, or flips over the back, then the operator doesn't have much of a chance.
With ROPS, the question is whether the operator will fall quicker than the tractor. For a low speed flop to the side with ROPS, there likely is a point near 45° where the tractor has passed the point of no return, but still is rolling slowly, and if an operator slips and falls, they could land in a danger zone before the tractor hits the ground.
This accident appears to have been a high speed accident, and the dynamics would have changed. A modern car likely would have spun out, slid sideways, but might have stayed upright.
With the tractor, once it hit a high speed over-steer, it likely didn't want to slide sideways, and the implement may have hit the rear tire at a 90° angle and forced it to remain sideways. All causing a massive deceleration and throwing the operator into the side window, and ultimately tipping the tractor, all with unfortunate results.
/ Fatal Tractor Rollover #38
The Infamous roll over My mother was the Kids School bus Driver! Seen the Rescue squad there when it happend. The roll over was a small CUT chained to a fence post. And the Throttle linkage was loose at the Inj. Pump and the Kid couldn't cut it off causing the tractor to roll over on him. She knew Wayne also. Ford was selling Tractors at the dealer then and my father was the Dealer Rep. for Ford credit. :censored:
/ Fatal Tractor Rollover #39
Seems odd the tractor looks to be turned around laying backwards. Going to fast and the implements Blades don't look to be in the position to be mowing. No uncut pass so he may not have been mowing. Hauling !!! down the Rd.? We've all pretty much BTDT. My BA. F-250 They Chipped the motor. True. How do I know. 3500rpms. 4th lockup. 373 they kill the Ing.. Frist trip to Fla. Int.75 late night. My father retired from ford and one of his dealers offered it to him. They window sticker states not to be used as a Emergency Veh... :rolleyes:
He wasn't pulling a mower.
/ Fatal Tractor Rollover #40
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
8ft. Fork Extensions (A59228)
8ft. Fork...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2017 FREIGHTLINER CASCADIA DAY CAB (A59908)
2017 FREIGHTLINER...
1997 JLG N40 Electric 40ft Articulating Boom Lift (A59228)
1997 JLG N40...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
