Fatal Tractor Rollover
/ Fatal Tractor Rollover #42
/ Fatal Tractor Rollover #43
That's tragic, very sad.
About 5 yrs ago a friend (with significant equipment experience) had a roll-over on his rural property - with no one around, he was pinned under the tractor for 5-6 hrs in a dry ditch. He eventually was able to move his hand, reach his cell phone. As I recall, a passer by eventually stopped. He was treated at the hospital, and made a full recovery. He shared this very powerful testimony with the Men's Ministry at church.
I often wonder if (for me, with some mobility issues) I would be better off wearing the seatbelt, or not. I think I'd rather be thrown than pinned. I have ROPS, no cab.... but I probably can't jump clear anyway.
/ Fatal Tractor Rollover #44
Mine will all do 33MPH.
They handle great, but my roads are narrow, unmarked and have vegetation growing well past the white lines, so there’s a sort of “swerving” as you drive to avoid losing mirrors.
I usually only do 25-33 bobtailing or pulling something small.
With a baler or a spreader, I usually keep it under 25.
I admit, I never wear seatbelts. 😣
I have never had any accidents except one time in a field, I had a 3” diam. branch punch through a side window and almost went through the side of my head. Also had a tire failure at high speed and I had to throw away my underwear after that one.
/ Fatal Tractor Rollover #45
Wear your seat belt. It increases your chances of survival, and we want you to keep posting. Another thing which helps even more is to not roll. ;)
One thing you learn in forklift training is that if they do go over it starts slow, giving you time to think that you can jump clear. Once they get to a certain point (45 degrees?) BOOM! They go fast.
I have never taken forklift training but a friend told me this after flipping his forklift while loading it onto his truck. 40 years later I still remember him wrapping his arm around the roll bar on the high side, to keep from getting under it. (No seat belt.)
/ Fatal Tractor Rollover #46
My worst fear is losing a tie rod or a front tire at road speed.
Already lost a tie rod, but was while loading spent mushroom compost in a field at 2MPH.
/ Fatal Tractor Rollover #47
I used to have a truck jacked up on 40" tires in my early 20's, and the bolts on the front U-joint on the rear driveshaft used to sometimes work loose. I forever had nightmares of that thing pogo-sticking me off the road, if I happened to drop the front end of the rear driveshaft onto the roadway at 60 mph.
/ Fatal Tractor Rollover #48
I actually did that on a jeep. Sheared the rear prop shaft off the yoke and it fell to the pavement.
It didn’t pogo stick, nor would it. They are hollow and not all that thick walled. It would either just grind down on the road, or fold & tear.
Vehicle is too heavy for pogo.
/ Fatal Tractor Rollover #49
I saw the results of that happen once. My neighbor left with his buddy in his jacket up Toyota to catch some trout... two hours later came back on a flatbed. They were going down the interstate doing about 65 when the front ujoint of the rear driveshaft failed, and they went end for end down the highway. He had just had both driveshafts rebuilt.
I could be mistaken but believe that newer vehicles have a cross member which keeps the driveshaft from hitting the ground if it fails.
/ Fatal Tractor Rollover #50
I operate at slower speeds than I could be going. I'm comfortable with the machine, and it works for me. Others (son in law, friends) with more experience could do tasks quicker, but I don't care. I'm learning as I go, and I get a lot more work done, than without a tractor.
Deere 335P (A53317)
Deere 335P (A53317)
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A59231)
2008 Regal 2565...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
Ratchet Straps (A59230)
Ratchet Straps...
