Oil & Fuel FarmPro 2425
/ FarmPro 2425 #21
Is there another screen in the system before the filte? how does one bleed the system?
Yes, several in fact. One inside the tank, another at the top of the sediment bowl. The typically there's at least one inline screen on a banjo fitting. Not all are the same, so - assuming you've inspected/cleaned the tank and bowl screens already -you'll have to pull both low pressure lines (the rubber ones) and visually inspect the fittings. One carries fuel from the sediment bowl to the fuel filter, another from the fuel filter to the injection pump. Any of those four fittings could have a screen.
Once we're sure your fuel path is unimpeded, we can work on priming/bleeding if necessary.
//greg//
/ FarmPro 2425
All of the fuel screens have been checked and cleaned or replaced. Next step, bleed the fuel system; instructions on this procedure please?
/ FarmPro 2425 #23
Sure. Again, make sure the fuel filter is full. Then locate the flexible hose between the filter and the injection pump (IP). Loosen the banjo bolt slightly at the IP end. Then use the hand primer until raw fuel runs out. That gets all the air out of the low pressure side. Secure the hand primer. Since it's only for the low pressure side, you shouldn't need it any more. The starter motor is used to bleed the high pressure side.
For that, start by locating the hardlines. They're the 3 steel lines between the IP and the 3 fuel injectors. Follow them to the top, and identify the hex collars that connect them with the injectors. Get an open end wrench and loosen all 3 hex collars no more than 1 turn. Tranny in neutral, brake set, compression release open; crank engine. Bubbles will appear at the hex collars. When you see the bubbles turn to raw fuel, tighten the associated collar. If you're still cranking, sometimes the engine will start just on that one cylinder. If it starts to run - even roughly - stop cranking. If not, repeat as required on the remaining two hex collars. Your tractor should be running by now.
//greg//
/ FarmPro 2425
To be sure I removed the sediment bowl and the screen and opened the fuel line petcock. The fuel drips from the tank. Is this normal or should the fuel run out in a steady stream?
/ FarmPro 2425 #25
There's one more screen. That fitting that was left under the tank when you removed the sediment bowl? Remove that too. The screen will come with it.
//greg//
/ FarmPro 2425 #26
You must un thread the fuel bowl from the fuel tank to get to the screen on the inside. You must first empty the fuel tank to do so. Once clean fuel should flow in a steady stream.
Chris
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
REEL RAIN HARD HOSE TRAVELER (A64278)
REEL RAIN HARD...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
