Oil & Fuel FarmPro 2425
   / FarmPro 2425 #21
Is there another screen in the system before the filte? how does one bleed the system?
Yes, several in fact. One inside the tank, another at the top of the sediment bowl. The typically there's at least one inline screen on a banjo fitting. Not all are the same, so - assuming you've inspected/cleaned the tank and bowl screens already -you'll have to pull both low pressure lines (the rubber ones) and visually inspect the fittings. One carries fuel from the sediment bowl to the fuel filter, another from the fuel filter to the injection pump. Any of those four fittings could have a screen.
Once we're sure your fuel path is unimpeded, we can work on priming/bleeding if necessary.
//greg//
   / FarmPro 2425
All of the fuel screens have been checked and cleaned or replaced. Next step, bleed the fuel system; instructions on this procedure please?
   / FarmPro 2425 #23
Sure. Again, make sure the fuel filter is full. Then locate the flexible hose between the filter and the injection pump (IP). Loosen the banjo bolt slightly at the IP end. Then use the hand primer until raw fuel runs out. That gets all the air out of the low pressure side. Secure the hand primer. Since it's only for the low pressure side, you shouldn't need it any more. The starter motor is used to bleed the high pressure side.
For that, start by locating the hardlines. They're the 3 steel lines between the IP and the 3 fuel injectors. Follow them to the top, and identify the hex collars that connect them with the injectors. Get an open end wrench and loosen all 3 hex collars no more than 1 turn. Tranny in neutral, brake set, compression release open; crank engine. Bubbles will appear at the hex collars. When you see the bubbles turn to raw fuel, tighten the associated collar. If you're still cranking, sometimes the engine will start just on that one cylinder. If it starts to run - even roughly - stop cranking. If not, repeat as required on the remaining two hex collars. Your tractor should be running by now.
//greg//
   / FarmPro 2425
To be sure I removed the sediment bowl and the screen and opened the fuel line petcock. The fuel drips from the tank. Is this normal or should the fuel run out in a steady stream?
   / FarmPro 2425 #25
There's one more screen. That fitting that was left under the tank when you removed the sediment bowl? Remove that too. The screen will come with it.
//greg//
   / FarmPro 2425 #26
You must un thread the fuel bowl from the fuel tank to get to the screen on the inside. You must first empty the fuel tank to do so. Once clean fuel should flow in a steady stream.
Chris
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
