Farmall Cub questions
   / Farmall Cub questions #1
jakieboy
Stevensville, Montana
1948 International Farmall cub
How do I test the condenser and the coil? Tractor has a J4 magneto.
   / Farmall Cub questions #4
Google is or can be your best friend. I found my original link via google. Just google IHC J4 magneto test and go from there.
   / Farmall Cub questions #5
Have a friend hold the coil wire while you crank it ����
   / Farmall Cub questions #7
condensers are capacitors. test them with an ohm meter.
short the pigtail to the body to discharge it.
set a meter to Rx1
put leads on the pigtail and body. On an analog meter, the needle will swing from 0 ohms to infinite. On a digital it will go from a low reading, probably auto range a bit, then indicate infinite.
Condensers that read infinite all the time are open, ones that read 0/low and never increase are shorted.
   / Farmall Cub questions #8
They cost 5 bucks change it
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
CATERPILLAR D6K2 LGP CRAWLER DOZER (A60429)
CATERPILLAR D6K2...
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
207271 (A52708)
207271 (A52708)
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
