Farmall Cub questions
/ Farmall Cub questions
/ Farmall Cub questions #4
Google is or can be your best friend. I found my original link via google. Just google IHC J4 magneto test and go from there.
/ Farmall Cub questions #5
Have a friend hold the coil wire while you crank it ����
/ Farmall Cub questions #7
condensers are capacitors. test them with an ohm meter.
short the pigtail to the body to discharge it.
set a meter to Rx1
put leads on the pigtail and body. On an analog meter, the needle will swing from 0 ohms to infinite. On a digital it will go from a low reading, probably auto range a bit, then indicate infinite.
Condensers that read infinite all the time are open, ones that read 0/low and never increase are shorted.
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
Frontier Hay Spear (A64126)
Frontier Hay Spear...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
1999 Dorsey 42' Aluminum Citrus Trailer (A64127)
1999 Dorsey 42'...
