Farmall 50 ?
/ Farmall 50 ? #1
Lucky Dog
Midland, MI
TYM 4820c
Any opinions on a Famall 50 with cab and hydrstat transmission?
A 2010 is up for sale near me and Was going to take a look at it.
Any thoughts? Good? Bad?
Thanks.
/ Farmall 50 ? #2
Don’t know if this is the same but I had a 2018 farmall 50a. Was a good hay tractor for the 300 or so hours i owned it. Only issues I really had was a neutral sensor and starter both around 50 hours of me buying.
Worked a 3 bottom plow, disc, and tiller at times too but it spent most of its time with a 489 haybine and 315 baler.
/ Farmall 50 ? #3
Was your neutral switch problem on the H-N-L shifter? If so, how did you fix it? I have a 70A and I’m having an issue with that neutral switch. I have replaced the switch and still having the same problem. Not sure if there is an adjustment that needs to be made or not.
/ Farmall 50 ? #4
Mine was on the same shifter. I did just replace the sensor and everything worked afterwards. No adjustments or anything else. Hope ya get yours figured out
