Farmall 50 ?
/ Farmall 50 ? #1
Lucky Dog
Midland, MI
TYM 4820c
Any opinions on a Famall 50 with cab and hydrstat transmission?
A 2010 is up for sale near me and Was going to take a look at it.
Any thoughts? Good? Bad?
Thanks.
/ Farmall 50 ? #2
Don’t know if this is the same but I had a 2018 farmall 50a. Was a good hay tractor for the 300 or so hours i owned it. Only issues I really had was a neutral sensor and starter both around 50 hours of me buying.
Worked a 3 bottom plow, disc, and tiller at times too but it spent most of its time with a 489 haybine and 315 baler.
/ Farmall 50 ? #3
Was your neutral switch problem on the H-N-L shifter? If so, how did you fix it? I have a 70A and I’m having an issue with that neutral switch. I have replaced the switch and still having the same problem. Not sure if there is an adjustment that needs to be made or not.
/ Farmall 50 ? #4
Mine was on the same shifter. I did just replace the sensor and everything worked afterwards. No adjustments or anything else. Hope ya get yours figured out
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
72in. Fork Extension (A64553)
72in. Fork...
2020 BOBCAT E35i EXCAVATOR (A65053)
2020 BOBCAT E35i...
USA Flag Metal Sign (A64557)
USA Flag Metal...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
