Farm Pro 2420
/ Farm Pro 2420 #1
luck3
farm pro 2420
Hi my name is chuck and i just got me a used farm pro 2420. I don't know much abouth tractors since this is my first one. My question would be on how to hook up the hydraulic lines from a koyker 160 on to the tractor. I got the loader mounted but now are stuck I dont know where to connect the pressure and the return line.
Thanks
/ Farm Pro 2420 #3
Mine, a 204 with a 140 Koyker.
There are (or should be) two lines connected together with a quick connect on the tractor, right side, disconnect these and connect them to your loader. DO NOT run the tractor without these lines either being connected back together--or-- to the loader, if you do you'll deadhead the pump, an expensive proposition.
Post back and tell us how you made out or any probs and I'll post a pic of mine, oh and welcome :) .....Mike
**EDIT**
I just thought, have you any idea if the fluids have been changed, hydro, trans, oil, coolant, diffs? It's a prerequisite of owing a Chinese tractor that the fluids be changed immediately after purchase, the ones they use from the factory leave a lot to be desired.
/ Farm Pro 2420 #4
Thanks
Hi Chuck!
Asian Tractor Parts has a great selection of Chinese built tractor parts that are factory direct! check out www.asiantractorparts.us for a list of parts. They have great customer service and helpful with troubleshooting! Definitely recommend
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
3pt 4' Rhino SE4 (A64127)
3pt 4' Rhino SE4...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
Front Tank Bracket (A64126)
Front Tank Bracket...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
