Farm Pro 2420
/ Farm Pro 2420 #1
luck3
farm pro 2420
Hi my name is chuck and i just got me a used farm pro 2420. I don't know much abouth tractors since this is my first one. My question would be on how to hook up the hydraulic lines from a koyker 160 on to the tractor. I got the loader mounted but now are stuck I dont know where to connect the pressure and the return line.
Thanks
/ Farm Pro 2420 #3
Mine, a 204 with a 140 Koyker.
There are (or should be) two lines connected together with a quick connect on the tractor, right side, disconnect these and connect them to your loader. DO NOT run the tractor without these lines either being connected back together--or-- to the loader, if you do you'll deadhead the pump, an expensive proposition.
Post back and tell us how you made out or any probs and I'll post a pic of mine, oh and welcome :) .....Mike
**EDIT**
I just thought, have you any idea if the fluids have been changed, hydro, trans, oil, coolant, diffs? It's a prerequisite of owing a Chinese tractor that the fluids be changed immediately after purchase, the ones they use from the factory leave a lot to be desired.
/ Farm Pro 2420 #4
Thanks
Hi Chuck!
Asian Tractor Parts has a great selection of Chinese built tractor parts that are factory direct! check out www.asiantractorparts.us for a list of parts. They have great customer service and helpful with troubleshooting! Definitely recommend
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
CAT 320 CL GP Bucket (A68134)
CAT 320 CL GP...
2013 KENWORTH T800 (A67714)
2013 KENWORTH T800...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
