farm king mower issue
   / farm king mower issue #1
laurencen
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Well finaly got the grass and weeds down on my field, having issues with the nower, after a hour of cutting the blades litrally stall, taking a look underneath the underside of the deck is full of pacled cuttings like mud, it is stopping the blades turning, I have hit many rocks while cutting but the blades are not that bad, it is very hard packed but will come off with a putty knife, is this normal, could it be the crop material I cut down
Thanks in advance for any ideas
   / farm king mower issue #2
Clean it up good and then spray some silicone lube under there.
Are you running at correct pto speed? discharge chute open?
soundguy
   / farm king mower issue #3
Is it a Farm King finish mower or bush hog style rotary cutter? I would expect the packed material on a finish mower but not the rotary cutter. I'd also check to be sure the blades are on right, and not installed upside down.
   / farm king mower issue #4
i used to have the same problem with my 84" farm king, i painted the underside of the mower with slip plate, i also suggest spraying with silicone before mowing
thanks for the ideas, the blades are on correctly, cleaned it up and it still sticks, not as bad but eventually the blades jam into the packed material on the sides, I will try sharpening them today and try again
Laurence
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
Mini Excavator (A55787)
Mini Excavator...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
Decorative Pig Statue (A55758)
Decorative Pig...
2020 Club Car Onward HP Li ION Electric Cart. (A53424)
2020 Club Car...
New Holland 57 Rake (A53316)
New Holland 57...
