Fan hits fan shroud - am I asking too much of this tractor?
   / Fan hits fan shroud - am I asking too much of this tractor? #11
Should be ample clearance between fan and shroud. Its not uncommon to swap fan belts by routing them between the fan and shroud
to get them on and off. Maybe someone can check theirs for you with the same model.
   / Fan hits fan shroud - am I asking too much of this tractor? #12
A 'kiss' solution.
If all else fails to find like a loose component or damaged part---
carefully nip or grind about 1/8 or 1/4 inch from each fan blade.
That little amount would not hinder cooling.
   / Fan hits fan shroud - am I asking too much of this tractor? #14
Broken motor mount or loose?
Most tractors don't have engine mounts. The engines are mounted directly to the transmission housing with a sub frame to support the front axle. Yes, there are exceptions but it's not the case.
   / Fan hits fan shroud - am I asking too much of this tractor? #15
Well, then how about a cracked mount? Somethings is fishy.
   / Fan hits fan shroud - am I asking too much of this tractor? #16
How about a cracked or broken shroud mount
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
Modine Shop Heater (A51573)
Modine Shop Heater...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
