Fan hits fan shroud - am I asking too much of this tractor?
   / Fan hits fan shroud - am I asking too much of this tractor? #11
Should be ample clearance between fan and shroud. Its not uncommon to swap fan belts by routing them between the fan and shroud
to get them on and off. Maybe someone can check theirs for you with the same model.
   / Fan hits fan shroud - am I asking too much of this tractor? #12
A 'kiss' solution.
If all else fails to find like a loose component or damaged part---
carefully nip or grind about 1/8 or 1/4 inch from each fan blade.
That little amount would not hinder cooling.
   / Fan hits fan shroud - am I asking too much of this tractor? #14
Broken motor mount or loose?
Most tractors don't have engine mounts. The engines are mounted directly to the transmission housing with a sub frame to support the front axle. Yes, there are exceptions but it's not the case.
   / Fan hits fan shroud - am I asking too much of this tractor? #15
Well, then how about a cracked mount? Somethings is fishy.
   / Fan hits fan shroud - am I asking too much of this tractor? #16
How about a cracked or broken shroud mount
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
71054 (A49346)
71054 (A49346)
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
Gehl 1870 Round Baler (A50514)
Gehl 1870 Round...
