Fan hits fan shroud - am I asking too much of this tractor?
   / Fan hits fan shroud - am I asking too much of this tractor? #11
Should be ample clearance between fan and shroud. Its not uncommon to swap fan belts by routing them between the fan and shroud
to get them on and off. Maybe someone can check theirs for you with the same model.
   / Fan hits fan shroud - am I asking too much of this tractor? #12
A 'kiss' solution.
If all else fails to find like a loose component or damaged part---
carefully nip or grind about 1/8 or 1/4 inch from each fan blade.
That little amount would not hinder cooling.
   / Fan hits fan shroud - am I asking too much of this tractor? #14
Broken motor mount or loose?
Most tractors don't have engine mounts. The engines are mounted directly to the transmission housing with a sub frame to support the front axle. Yes, there are exceptions but it's not the case.
   / Fan hits fan shroud - am I asking too much of this tractor? #15
Well, then how about a cracked mount? Somethings is fishy.
   / Fan hits fan shroud - am I asking too much of this tractor? #16
How about a cracked or broken shroud mount
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
