The service manual is pretty vague on troubleshooting. Pull the panel where the switch is located. You should have power on one wire when the switch is off. The manual then says that power is fed to another terminal when L-M-H is selected. Power is also fed to the individual LMH terminals for a total of 5 terminals. If you switch has power and seems to be working, check power and ground at the blower.
