Fan Blower Switch or Fan replacement
   / Fan Blower Switch or Fan replacement #1
Kurtis22
MN
5600 Toolcat
Blower or switch is bad. Trying to figure out the issue by tomorrow morning. Its a snow plow machine and snow is on its way for Southern Minnesota. Has anyone replaced theirs? Any insight would be appreciated?
   / Fan Blower Switch or Fan replacement #2
Did you check the #7 fuse that is under the operators seat?
   / Fan Blower Switch or Fan replacement #3
If you are sure is the switch, put a temporary jumper across it.
   / Fan Blower Switch or Fan replacement #5
The service manual is pretty vague on troubleshooting. Pull the panel where the switch is located. You should have power on one wire when the switch is off. The manual then says that power is fed to another terminal when L-M-H is selected. Power is also fed to the individual LMH terminals for a total of 5 terminals. If you switch has power and seems to be working, check power and ground at the blower.
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
24008 (A53422)
24008 (A53422)
Willmar 4500 Wrangler Articulating Loader (A55314)
Willmar 4500...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
