Fan Blower Switch or Fan replacement
/ Fan Blower Switch or Fan replacement #1
Kurtis22
MN
5600 Toolcat
Blower or switch is bad. Trying to figure out the issue by tomorrow morning. Its a snow plow machine and snow is on its way for Southern Minnesota. Has anyone replaced theirs? Any insight would be appreciated?
/ Fan Blower Switch or Fan replacement #2
Did you check the #7 fuse that is under the operators seat?
/ Fan Blower Switch or Fan replacement #3
If you are sure is the switch, put a temporary jumper across it.
/ Fan Blower Switch or Fan replacement #5
The service manual is pretty vague on troubleshooting. Pull the panel where the switch is located. You should have power on one wire when the switch is off. The manual then says that power is fed to another terminal when L-M-H is selected. Power is also fed to the individual LMH terminals for a total of 5 terminals. If you switch has power and seems to be working, check power and ground at the blower.
2011 CATERPILLAR 299C SKID STEER (A62129)
2011 CATERPILLAR...
2019 Chevrolet Colorado Pickup Truck, VIN # 1GCGTCEN7K1209874 (A61165)
2019 Chevrolet...
2004 Ford F-250 Service Truck with Lift Gate (A61568)
2004 Ford F-250...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
UNUSED CFG INDUSTRIAL MX15RX MINI SKID STEER (A62130)
UNUSED CFG...
2017 Ford F-250 Service Truck (A61568)
2017 Ford F-250...
