Failed Stabilizer bars
/ Failed Stabilizer bars #21
Ya I guess I should get a new stabilizer for that side. Seems like a weak link in the system.
/ Failed Stabilizer bars #22
I think I would talk to the dealer about upgrading to a larger stabilizer bar from a larger tractor for those of you with bent/ broken. If the warranty doesnt cover it, I for sure wouldnt buy the same size that broke. If I couldnt buy one heavy enough to keep from breaking, I would fabricate my own or get a shop to do it if you arent equipped to do it. You could use the existing one for a pattern and just beef it up . Rectangular tubing and flat bar would work for this. Some tractors use that material rather than round stock.
/ Failed Stabilizer bars #23
I agree with Gary don't buy original, beef it up. Luckily with my 7010c I haven' t had any issues and I bush hogged a 5 acre area with an abundance of 4" diameter plus hardwood trees and the stabilizers are fine,but I had to beef up and reweld the perimeter welds on the feed end of my new land pride bush hog because one pass is just not sufficient when you are ramming 4" plus diameter hardwood thru the hog.
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2016 PETERBILT PB320 GARBAGE/SANITATION TRUCK (A59823)
2016 PETERBILT...
2007 Chevrolet C6500 Landscape Dump Truck (A59230)
2007 Chevrolet...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
