Failed Lug/Stud
/ Failed Lug/Stud #1
ThisldooFarm
Upstate NY
B7800
B7800. I was changing the front wheels. One of the six studs/lugs came off with the nut intact. The hub threads were stripped. I suspect this happened during initial intalllation. What to do? They appear to be threaded the same as the nuts. Is there a retrofit splined lug? Retap with larger lug? Ignore and just use the remaining 5 lugs until one of these fails? Any help would be apprecieated. Thanks again.
/ Failed Lug/Stud #2
You could try repairing the threads with a thread repair kit or buy a replacement hub.
/ Failed Lug/Stud #3
Heli coil kit/ thread repair kit would be cheaper and easier to install than anything else.
/ Failed Lug/Stud
Great idea. Do they make them in metric? Any idea where to get? NAPA?
Thanks.
/ Failed Lug/Stud #5
Yes they make them in metric and NAPA does sell them. I'm not sure if they will have the size you need but they can probably order it for you if they don't.
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
EZ Flow Mod. 300...
Mitas Tire (A65640)
Mitas Tire (A65640)
New Holland 273 Square Baler (A66408)
New Holland 273...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
