failed locking pin on locking chain grab hook - am i doing it wrong?
   / failed locking pin on locking chain grab hook - am i doing it wrong? #32
   / failed locking pin on locking chain grab hook - am i doing it wrong? #33
These are for the people who do not like stake pockets as tie downs. https://www.amazon.com/Hydraker-Rem...t=&hvlocphy=9012068&hvtargid=pla-835310952698
2000lbs?
   / failed locking pin on locking chain grab hook - am i doing it wrong? #34
If you want D-rings please use 3/4" or 1".
   / failed locking pin on locking chain grab hook - am i doing it wrong? #35
A stake pocket is better for hooking a chain than that is.
I do not use them. I see no need for them. There are people that do not like to use the stake pocket. For info only. As to the size of the D-ring look at the WLL on each part of your securement.
As in another thread the grade and size of the chain or other parts of the securement is important. Not just the size. A 1/4 grade 70 chain is stronger then a 3/8 common chain. You need to look at the WLL of each piece.
   / failed locking pin on locking chain grab hook - am i doing it wrong? #36
I've never lost a chain using a stake pocket. If you attach the chain correctly, the weight of the chain will keep the hook in place. I also never used more than one chain binder. Both chain hooks were placed in the stake pockets, then I would pull the slack to one side and put the binder in a convenient spot. Tighten the binder, then take the loop of chain in between the two binder hooks and wrap it around the binder and tie with a wire. I drove a hotshot truck for a while delivering vehicles into the oil patch and ranches, so I got lots of practice. DOT guys never questioned my manner of doing things. The main pita was having to chain both the bucket and the scoops on backhoes. It was overkill, but I was told any and all attachments required a chain.
   / failed locking pin on locking chain grab hook - am i doing it wrong? #38
mbs12000lbs
max breaking strength 12000 lbs
Seems I can not read well I my old age. A 12000 shear is not all that much, that is what, a 4500lb working strength?
Need to find that old chart I have around here somewhere. I know it is less than half...
   / failed locking pin on locking chain grab hook - am i doing it wrong? #39
If I remember right, G70 in 5/16 chain is 4700 pounds.
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
