Fail vs RFM
/ Fail vs RFM #1
nhman
Virginia
Kubota B2910
I have a b7500 Kubota - 21 hp. I'd like to pull a rear mount 72" grass cutting attachment. I've had a local dealer recommend a 72" flail mower. My question is my tractor big enough to pull a 72" mower? The recommendation from the dealer is to go with a flail mower because it's closer to the back end of the tractor and will not cause the front end to lift up. Dealer says the tractor should have enough horse power for it as long as I'm cutting at 4". I could put the front loader on for weight, but I wonder if a 72" unit is doable. My first choice is of course a larger tractor, but the boss won't agree. I am mowing about 6 acres of pasture.
Anyone with experience pulling a 72" rear mount mower with a b7500 kubota?
nhman
/ Fail vs RFM #2
I guess that I would not put that on my 27hp tractor, would stick to a 60 inch. Weight of the unit would not be a consideration since I have a fel on. Just to much area for the hp.
/ Fail vs RFM #3
nhman
A 72” RFM would be a little heavy for a 7500. It may require more horsepower than a B7500 has.
A 72” Flail mower will be lighter and will require less horsepower to run.
If you need a 72” mower the Flail may be the best choice for your size tractor.
/ Fail vs RFM #4
If the local dealer recommends the 72" flail tell him
to bring one OUT and let u DEMO it.
My local Deere and NH dealers both let me demo about anything I
want.
/ Fail vs RFM #5
Sorry but you don't have the horses to spin 6 ft of anything. Your tractor could handle a tow behind sickle bar mower that size.
/ Fail vs RFM #6
Nhman,
I import a 49" drum mower for compact tractors. Just needs 20 hp. It does not need external hydraulics. Call Sweet tractors they can buy from me wholesale.
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2007 Mazda 3 Hatchback (A61574)
2007 Mazda 3...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
UNUSED SDLANCH 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
