Fabed up a fork attachment for the PT180, found its limit
   / Fabed up a fork attachment for the PT180, found its limit #1
m5040
CT
Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
I adapted a forklift attachment to the PT180 quick attach plate and went to try it out before a (someday) flat black paint job. It lifted a boulder that I couldn't roll into the bucket. The forks slid under without pushing the boulder away, and the ability to tilt it so far back made it so the weight was more manageable even know the rear was light. I could only make gradual turns or the rear tire(s) would lift.
I loaded the Kubota bucket. The Power trac didn't tear up the grass like the Kubota would have done and the wide bucket would have made a mess getting the boulder in it.
Which springs are you referring too?
   / Fabed up a fork attachment for the PT180, found its limit #4
I think he's looking at the springs for the attachment locks.
   / Fabed up a fork attachment for the PT180, found its limit #5
Those springs might be providing downward pressure on the pins on the quick attach plate.
Yes, the economy PT180 has a manual locking quick connect. You have to manually pull up on the pins, twist a few degrees to lock in the up position, then change your attachment. When changed, just give a slight twist, and the springs push the pins down to lock in the new attachment. It is so easy I forgot to do it once with the mower and when I got to the area and floated the loader arms, the mower started off in its own direction.....for a micro second it was WHAT IS GOING ON HERE????
   / Fabed up a fork attachment for the PT180, found its limit #7
Don't feel bad... I've done that with several attachments on my 425. :laughing:
   / Fabed up a fork attachment for the PT180, found its limit #9
I've done it with the mower and a bucket. And forks. :laughing:
   / Fabed up a fork attachment for the PT180, found its limit #10
And snowplow, now that I think about it. :laughing:
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
JCB 3C 15' BACKHOE (A60429)
JCB 3C 15' BACKHOE...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
