F935 value? also, JD430?
/ F935 value? also, JD430? #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
Hi, I have 2 different ride on mowers and only need to keep one. Trying to get an idea on realistic sale prices.
1) model year 2000 F935 front mower, 72" commercial deck, ROPS & roof. DIESEL. 1800 hours. Full service just done with new air filters, motor oil, tranny oil & filters. New rad & new coolant ALL JD fluids (except motor oil). Everything greased regularly. I also replaced the driveshaft isolator and shimmed motor so it connects inline/level to the isolator and driveshaft (a common issue for these).
2) JD 430 tractor/mower. DIESEL. 3000 hours, runs strong and perfect. ALL same fluids & filters were recently replaced. This is sort of a tractor or a monster mower. I have it set up as a mower with 60" deck. Also has a separate grass catching system powered by a 5HP Honda engine for the blower (oil changed, carb cleaned on that too). It has 3 hydraulic levers, one for lifting deck, one for the front hydraulics (could add bucket/boom), not sure on 3rd lever.... Has a rear PTO shaft and you can get a 3 point hitch for $300.
So what should I expect to get for these? Whichever one sells, I'll keep the other. I like both. Thanks for your help.
/ F935 value? also, JD430? #2
The 430 is a great classic JD that is highly sought after on the used market. Clean ones will bring a good price, especially with your optional equipment. The two outside hydraulic levers connect to the outlets on the front of the tractor. One is used to raise a front attachment such as a blade, and the other for right/left angling of it.
/ F935 value? also, JD430? #3
My dealer had a John Deere 430 with just under 2000 hours on his lot for $3400 last week.
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2017 Ford F-250 Ext. Cab Pickup Truck (A61573)
2017 Ford F-250...
2019 MACK PINNACLE (A63569)
2019 MACK PINNACLE...
Club Car DS Golf Cart (A64047)
Club Car DS Golf...
