F3990 Stalling
/ F3990 Stalling
It ended up being debris in the fuel tank. A small piece of leaf would block off the fuel inlet.
  • Good Post
Reactions: fc1
/ F3990 Stalling #12
Recently my F3990 has started stalling when mowing. it doesn't appear to be losing power, just stop running. It always starts right up without hesitation immediately after so I can continue mowing.
I replaced both fuel filters and it worked fine for a few weeks, but has started up again. I blew out the fuel hose from the first filter into the tank, but that didn't do anything. When I look at the fuel level in the first filter, the one between the pump and the tank, it is never more than 20% full. Is this normal?
Any suggestions on what I can look into next?
thanks
I had the same problem and wired around the seat sensor and it fixed mine....js
2020 KENWORTH T270 SERVICE TRUCK (A59823)
2020 KENWORTH T270...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2015 Kubota L4701 (A60462)
2015 Kubota L4701...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
