F2560 hydrostatic transmission fill and drain
   / F2560 hydrostatic transmission fill and drain #1
Mikefromcny
Upstate NY
White 2-65, Kubota B9200
Hi all,
2004 f2560 owner here. 2500 hours. Ordered a service manual but haven't seen it yet. Would anyone happen to know where the fill/drain would be on the transmission? I've looked all over and it isn't super obvious.
   / F2560 hydrostatic transmission fill and drain #2
Routine maintenance should be covered in an operator manual, which may be available on the web.
   / F2560 hydrostatic transmission fill and drain #3
Make sure you clean the screen. Mine was full of trash.
Where is that located? Sounds like I need to pull the sheet metal off and give it a good pressure washing.
   / F2560 hydrostatic transmission fill and drain #5
I have a 3680 so not sure it's same location. Right side of transmission. It looks like a bolt that comes out.
   / F2560 hydrostatic transmission fill and drain #6
Hi all,
   / F2560 hydrostatic transmission fill and drain #7
I have F2560 operators manual in pdf and can email it if you send me a private message.
Pages 40 & 41 show exactly where the strainer and drains are.
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52128)
Heavy-Duty...
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
