F2560 hydrostatic transmission fill and drain
   / F2560 hydrostatic transmission fill and drain #1
Mikefromcny
Upstate NY
White 2-65, Kubota B9200
Hi all,
2004 f2560 owner here. 2500 hours. Ordered a service manual but haven't seen it yet. Would anyone happen to know where the fill/drain would be on the transmission? I've looked all over and it isn't super obvious.
   / F2560 hydrostatic transmission fill and drain #2
Routine maintenance should be covered in an operator manual, which may be available on the web.
   / F2560 hydrostatic transmission fill and drain #3
Make sure you clean the screen. Mine was full of trash.
Where is that located? Sounds like I need to pull the sheet metal off and give it a good pressure washing.
   / F2560 hydrostatic transmission fill and drain #5
I have a 3680 so not sure it's same location. Right side of transmission. It looks like a bolt that comes out.
   / F2560 hydrostatic transmission fill and drain #6
Hi all,
   / F2560 hydrostatic transmission fill and drain #7
I have F2560 operators manual in pdf and can email it if you send me a private message.
Pages 40 & 41 show exactly where the strainer and drains are.
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
197359 (A50458)
197359 (A50458)
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
