F2560 hydrostatic transmission fill and drain
   / F2560 hydrostatic transmission fill and drain #1
Mikefromcny
Upstate NY
White 2-65, Kubota B9200
Hi all,
2004 f2560 owner here. 2500 hours. Ordered a service manual but haven't seen it yet. Would anyone happen to know where the fill/drain would be on the transmission? I've looked all over and it isn't super obvious.
   / F2560 hydrostatic transmission fill and drain #2
Routine maintenance should be covered in an operator manual, which may be available on the web.
   / F2560 hydrostatic transmission fill and drain #3
Make sure you clean the screen. Mine was full of trash.
Where is that located? Sounds like I need to pull the sheet metal off and give it a good pressure washing.
   / F2560 hydrostatic transmission fill and drain #5
I have a 3680 so not sure it's same location. Right side of transmission. It looks like a bolt that comes out.
   / F2560 hydrostatic transmission fill and drain #6
Hi all,
   / F2560 hydrostatic transmission fill and drain #7
I have F2560 operators manual in pdf and can email it if you send me a private message.
Pages 40 & 41 show exactly where the strainer and drains are.
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2018 Ford F-150 (A51039)
2018 Ford F-150...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
