F2260 Kubota
/ F2260 Kubota #1
jtj483
My F2260 mower will intermittently shut down and will crank right back up. I have replaced fuel pump, fuel shut-off switch, & cleaned fuel tank to but it continues to shut down occasionally. Any ideas?
/ F2260 Kubota #2
Welcome to the Forum. So...
Does it loose power and slow down and stall like there was a fuel starvation problem, or does it shut off just like you turned the key or jumped off the seat? First play would be fuel system (tank suction hose is off or plugged, tank air bleed is losed/plugged, or the second play would be electrical (safety switches, PTO lever, overheat sensor, parking brake or even a short to ground from mice dining on a critical wire).
/ F2260 Kubota
Cuts off like turning key off. Checked all fuel lines, seem to be in good shape. Shut-off switch in seat was removed when when I got it.
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2018 CAT 259D Skid Steer (A62613)
2018 CAT 259D Skid...
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
John Deere 8320R (A64126)
John Deere 8320R...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
