F2260 Kubota
/ F2260 Kubota #1
jtj483
My F2260 mower will intermittently shut down and will crank right back up. I have replaced fuel pump, fuel shut-off switch, & cleaned fuel tank to but it continues to shut down occasionally. Any ideas?
/ F2260 Kubota #2
Welcome to the Forum. So...
Does it loose power and slow down and stall like there was a fuel starvation problem, or does it shut off just like you turned the key or jumped off the seat? First play would be fuel system (tank suction hose is off or plugged, tank air bleed is losed/plugged, or the second play would be electrical (safety switches, PTO lever, overheat sensor, parking brake or even a short to ground from mice dining on a critical wire).
/ F2260 Kubota
Cuts off like turning key off. Checked all fuel lines, seem to be in good shape. Shut-off switch in seat was removed when when I got it.
2014 CASE 580N BACKHOE (A65053)
2014 CASE 580N...
2024 BOBCAT S76 R-SERIES SKID STEER (A65053)
2024 BOBCAT S76...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
