F215 electrics
/ F215 electrics #1
nevis
England
Yanmar F215
When I bought my F215 (which is a fantastic tractor) a couple of months ago I found that the regulator/rectifier did not work and the instruments did not work because the fuse was blown.
I put new fuse in and all instruments worked until the engine was started and revved - then the fuse blew again.
I put this down to the non working regulator - there is 25V AC at the battery terminals - Am I correct or should I be looking for a short somewhere ?
I have been trying to buy a regulator/rectifier in the UK ever since with no success so far - will the unregulated voltage damage anything and can anyone supply this unit to me the UK?
Thanks and Regards Andy
/ F215 electrics #2
It will damage your battery:eek: :eek: :eek:
/ F215 electrics #3
25 volts is way too high, you will overcharge your battery, warp the plates/boil it dry, plus you could burn the alternator out too!
Usual charge voltages for lead acid batteries fall in the ranges of 13.8 to just over 14 volts.
/ F215 electrics #4
25vac out of the alternator is correct; however, he does need to replace that regulator/rectifier to get proper DC voltage to the battery.
/ F215 electrics #5
I agree with all the above. You can charge your battery with a battery charger and disconnect the alt. leads. It will start several times between charges. You can then use your tractor until you find the parts.
/ F215 electrics #6
I'm not in the UK, but I have the regulator, your F215 also has a current limiter.
Danny
/ F215 electrics
Danny
You say the 215 also has a current limiter - is this a separate unit to the rectifier ie do I need 2 components?
Can I simply disconnect the alternator lead connector and run the tractor without damaging the alternator?
3ft Teakwood Indian (A65583)
3ft Teakwood...
New/Unused Landhonor Quick Attach Grapple Bucket (A65583)
New/Unused...
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
2014 FORD F350 4X2 S/A DUMP TRUCK (A59914)
2014 FORD F350 4X2...
20ft. x 8ft. Shipping Container (A65640)
20ft. x 8ft...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
