F16 Koyker Loader Install
/ F16 Koyker Loader Install
Brent,
Do you have the 2 hose or 3 hose setup? I am familiar with the 2 hose set-up, it's this 3rd hose I am having trouble with.
Matt
/ F16 Koyker Loader Install #12
I'm confused. PB is used to continue the circuit to another valve, Yes? If you pick up pressure after the pump and then take the out back to the closest place you just connected for input then PB is not even used. These are open center system, so they have fluid flowing all the time through the In and Out sports of the valve.
Whe I installed my FEL I connected to the 3 Pt valve & it was a mistake as it is too low in volume. To correct this I am going to "T" into the high pressure line coming out of the pump then go back to it from the out port. Had I done that initially I wouldn't have had to worry about the 3 Pt as it was already plumbed, but I was trying to use a valve to activate the float control on the 3 PT. I connected it in serial with the FEL valve. Everything works, but the FEL is slow because of the volume issue.
PB continues the pressure to the 3 pt. The problem I am having is there are two "out" ports on the loader valve body, one is pressure for the 3 pt/ PBY, the other seems to be a dump valve. If this is the case then I will just plumb it into the reservoir. I'm just trying to make sure there is no constant flow through this third line, otherwise there would be no power beyond the loader unless it ended up in the 3 pt valve body. I have a call into Koyker, but they haven't gotten back to me yet with the answer.
/ F16 Koyker Loader Install #14
Power Beyond supplies the high pressure fluid to next valve, the three point valve, and this contains the continuous open center flow.
The Out port is a low pressure feed back to the resovoir that is only used when fluid has to be pushed out of a cylinder or for the pressure relief valve in the FEL valve.
On an open center system without Power Beyond, the two circuits above are combined in one hose.
/ F16 Koyker Loader Install #15
blackd, please call me before you do what your planning!!!! 509-521-1507
/ F16 Koyker Loader Install #16
Hi - I've been searching for the easiest way to add remote hydraulics to my F215 and noticed that Tractors4u has used the hydraulic pipes underneath the right foot plate on an FX26 for a loader. The F215 has these pipes and a wing nut connected to a lever underneath the seat. If I connect remote hydraulics to these pipes and move the lever underneath the seat will the 3 point still work or do you need to switch between the two?
Regards
Andy
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
Kodiak 3pt 5' Mower (A60462)
Kodiak 3pt 5'...
