F14D Yanmar Tractor
/ F14D Yanmar Tractor #1
Yellowhammer
Hamilton, Alabama
Yanmar, F14D
I have had this tractor for about a year now and I am wanting to change the hyd. oil in it. So, where does the oil go and how much will it hold? I want to make sure before I start putting the oil into the wrong hole. Where could I get manuals for this tractor?
Thanks,
/ F14D Yanmar Tractor #2
Hi YellowHammer
I have an F15D and I changed mine as soon as I got the tractor.
I used Hytrans from Tractor supply, but as long as it meets the JD 303 spec you will be fine. 5 Gal's was enough to fill mine completely, with filter change.
You have two filters, 1 spin on under the right floorboard (see attachment) and a screen in the return line. If you follow the return line from the pump to the trans there is a flange with three screws, you have to remove this flange and a screen will be underneath. Clean this screen and replace. Under the seat there is a cap roughly an 1.5" in diameter which is the filler hole and near it is a yellow rubber cap that has the dipstick attached to it.
You can get an operators manual for it, I recently saw one on Ebay that was translated, I have a parts manual (that I bought from Hoye) that helps you visualize most things.
I got all my filters from NAPA but Hoye can help you out with these also.
FYI: NAPA Filter Numbers
Air 6270
Oil 1064
Fuel 3262
Hyd 1120
If you have any other questions, or would like some pictures PM me and I will help you out.
Tom
PS, fill out your profile and you will get a better response.
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
1989 Freightliner FC60 Day Cab Truck, VIN # 1FUP2DYBXKH356541 (A65563)
1989 Freightliner...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
