F Series Winter Storage
/ F Series Winter Storage #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
Anyone store their F tractor with the deck flipped up during the winter to save room? The only issue I can see is the gearbox might leak for some reason.
I need to change the gearbox fluid in the spring anyway, so I might do this either way.
Just curious if anyone had any bad experiences storing that way?
/ F Series Winter Storage #2
I store mine flat, since i remove mine from the machine to install the Snow Blower, but i wouldn't hesitate leaving it flipped up. Just remove from PTO and you might want to remove the belt spring for the winter
/ F Series Winter Storage #3
In mine, the 90 degree gearbox input and output shaft oil seals are identical and do not leak with the deck in either position.
I replaced all 4 tapered roller bearings and 2 oil seals last year just as a preventive maintenance due to minor slack in the bearings.
/ F Series Winter Storage #4
I store mine flat and roll it under my camper for the winter, where it's out of the way. I think you'd be fine storing it vertical. If the seals were to leak from storing it this way you'd probably have gear oil leaking during use also.
/ F Series Winter Storage #5
Don't see an issue if the deck is flipped up according to the manual. Disconnect the drive shaft and then flip it up. I to store mine flat, but also have enough room.
/ F Series Winter Storage #6
Store mine flat, but like was said earlier if it leaked while up it would probably leak while using it.
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A64556)
2006 Mack CV713...
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2010 Brenner...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2015 Ram 1500 Pickup Truck (A64556)
2015 Ram 1500...
