F Series Winter Storage
/ F Series Winter Storage #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
Anyone store their F tractor with the deck flipped up during the winter to save room? The only issue I can see is the gearbox might leak for some reason.
I need to change the gearbox fluid in the spring anyway, so I might do this either way.
Just curious if anyone had any bad experiences storing that way?
/ F Series Winter Storage #2
I store mine flat, since i remove mine from the machine to install the Snow Blower, but i wouldn't hesitate leaving it flipped up. Just remove from PTO and you might want to remove the belt spring for the winter
/ F Series Winter Storage #3
In mine, the 90 degree gearbox input and output shaft oil seals are identical and do not leak with the deck in either position.
I replaced all 4 tapered roller bearings and 2 oil seals last year just as a preventive maintenance due to minor slack in the bearings.
/ F Series Winter Storage #4
I store mine flat and roll it under my camper for the winter, where it's out of the way. I think you'd be fine storing it vertical. If the seals were to leak from storing it this way you'd probably have gear oil leaking during use also.
/ F Series Winter Storage #5
Don't see an issue if the deck is flipped up according to the manual. Disconnect the drive shaft and then flip it up. I to store mine flat, but also have enough room.
/ F Series Winter Storage #6
Store mine flat, but like was said earlier if it leaked while up it would probably leak while using it.
2014 KOMATSU PC138US-2E0 EXCAVATOR (A65053)
2014 KOMATSU...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
213087 (A64276)
213087 (A64276)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
86 (A63290)
86 (A63290)
