F Series vs. ZD
   / F Series vs. ZD #102
TBH I have not read all 10 pages before this post. But I'd bet you've gotten significant input from "both sides" of the issue.
All I'll tell you is that I have a 84" 3 pt finish mower that I mow my 5 acres for the past 8 years. My neighbor bot 5 acres next door a couple of years ago and bought a Scat ZT because he felt it would be faster than my rig.
Bottom line is it takes him 3½-4 hours to mow his 5 acres, takes me 2¼ hours for mine. And I have severe hills, he doesn't. If your acreage is bumpy at all, you'll regret the ZT.
Good Luck with your choice!
   / F Series vs. ZD #103
Why? I mow bumpy ground 2 full days per week with (2) ZD-1211-72” diesel zero turn and it flies over bumps, around trees, up & down hills with ease.
I couldn’t think of a faster way to cut grass than a zero turn. Time is money in my business. We have to get grass cut fast, or time/money is lost.
Zero turns whip around trees, along buildings, around landscape beds much faster than a tractor.
I DO realize the OP may not be in the hurry that I am in, that is why everyone views mowing from a different perspective. But in a mowing contest, I’ll whup a tractor in mowing speed, even if it has a 1-2 wider deck.
   / F Series vs. ZD #104
Strange, for years I mowed my 8 acre lawn with my 35HP tractor with 84" rear finish mower (took a little over 3 1/4 hours to mow)
Bought a 35HP zero turn with a 72" deck a decade ago and cut over an hour off my mowing time.
   / F Series vs. ZD #105
Rough ground is the one thing a 3 PH FM doesn't do well. I got you on the mower by almost 3 times. I have a 21' Frontier batwing. Flat open ground and i can probably cut any zero turn time in half at least. But it doesn't replace a zero turn. Not even close. I have 2 ZTs and I have 2 hours of cutting on them before I even hook up the big mower. Once I do that I'm done in 45 minutes.
   / F Series vs. ZD #106
Some perspective here:
Obviously, if we are talking about a 10 acre “football field” type of lawn, then yes, you might be able to cut faster with a tractor & pulled mower.
However, most large lawns have trees, buildings, landscape beds, etc. Trying to maneuver a 4 ton turf tractor with a pulled mower would be much slower than a zero turn in that more typical scenario.
   / F Series vs. ZD #107
I bought a used JD 1435 diesel front mower side discharge 7-iron at a local Metro Parks auction $2500. Yanmar motor. Starts on the 2 revolution even after sitting for a few months. Found a 60" front rotary broom for it and I will NEVER use or need a snowblower, plow or pusher again, and I've tried all 3 before getting a broom. The driveway is spotless after brooming snow and is dry in 1 hr. I can spray the snow even from 10" drifts as far out as I want or need to using rpm. And it does all this at 15 (measured) mph. The motor isn't even warmed up when I'm done.
As and added bonus, I bought a 3:1 gearbox with a 540 pto stub on it and can run my 45kW Winpower PTO genny off of it. The 1435 is about 22hp so its 11kw potential is plenty of electric power for us. I also still have my F935 earlier version of the 1435. It can also run the genny and a 76" rear discharge deck for chomping thru high field grass, weeds, trees, woodchucks, and whatever it chooses to munch on.
That’s a heck of a find!
   / F Series vs. ZD #108
Anyone know if there dealers will willingly install the air seat on zd1211. I asked this one and said they are not authorized to do it. They can special order it but want nothing to do with the swap out…
I’ve seen videos where people are ordering them with the air ride seat.
I have posted before changing ZD331 to Grammer air ride seat. It is a game changer on rough grounds
   / F Series vs. ZD #109
Actually, that's a typical price for these mowers used in all the Metropark sales. They have Fall auctions every year. (Auctions – Chuck Cryderman & Associates, LLC). I also bought a Toro diesel 72" zero turn and an ExMark diesel 72" zero turn at the same auction. The Toro and the Exmark are essentially the exact same machine.
All of their machines are well taken care of, just retirement from depreciation schedules or slightly broke. The heck of a find was a JD 4400 hydrastat with a loader, stuck in the low range (a common problem on the 4x00 series as the range selector rod is weakened by an O-ring groove AND the lever stop is mis-adjusted. The replacement part to fix the machine was in the LHS toolbox. Took longer to pull off the seat than to remove and install the new shifter rod. There was dirt in the hydraulic pressure relief valve that made the rear lift arms jerky. Wiped it off with my glove and stuck it back in.
   / F Series vs. ZD #110
I guess I could have said it better thats a heck of a deal in my area.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
