EZ Hitch
/ EZ Hitch #1
ckbrown98
MF 1726E
Wondering if anyone is using Carter and sons EZ Hitch instead of Pat's..what's your thoughts?
/ EZ Hitch #3
Carter's EZ hitch is well made. One advantage is that it does not extend the length of the PTO hookups.
/ EZ Hitch #6
Never heard of them before. Looks interesting however.
I have a brand (sorry I don’t remember the name) that is a cross between these with the pins and the mounting style similar to Pat’s.
My and Pat’s do increase the distance from the tractor about 4” which can create an issue with PTO shafts being short.
The only concern for this design that I notice is if you have a low pin level on an implement especially if an implement should sink on a stand or falls from a prop some how.
I could not tell from the picture how the spacer bar is removed. If it is not removable, it may well cause interference with a PTO shaft.
2019 PETERBILT 567 (A65643)
2019 PETERBILT 567...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2022 EZ-GO ELITE...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A59914)
2015 ALTEC AT200...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
