Extreme cold
/ Extreme cold #1
Saucymynx
LS MT7 101 Farmall 656 Ford 2610 Farmall 140. JD 670
Hello. Many of you, we are settling into extreme cold here in the far north. I don’t usually worry about things like this, but when the temperatures go down well below zero and stay there, I’m a bit worried about a couple of my tractors. I have a farmall 656 gas And a Farmall 856 diesel that are in an open front unheated shed. They of course have antifreeze in the cooling system, but I have not tested it. The gas has a circulating coolant heater and the diesel has a freeze plug heater. I have them both plugged in and just sitting there; I don’t plan on using them. My thought was to keep the heaters on during the worst of the cold. Is this a good idea? Do you guys ever do that? any other tips for extreme cold? Thanks.
/ Extreme cold #3
When I farmed in central MN always checked anti-freeze in the fall and never worried about them. Coldest I remember was two weeks where hi temp was minus 20 and low was minus 44 with chill around minus 100.
If you are concerned Heaters will prevent block from freezing.
/ Extreme cold #6
We are in for the cold here too. Tomorrow -15f hi temp with -45 wind chills. I don't plug in the engine block heater unless I plan to use the tractor. The heater does not have a thermostat and can possibly burn out from extended use.
My dealer said to plug in an hour or so prior to starting and no need to run much longer than that. That's what I was told.
/ Extreme cold #8
If you're not planning on using them, I would not be the least bit concerned as long as the coolant is at the proper SG to support the expected temps (I would shoot for 10 degrees below to be safe).
/ Extreme cold #10
Even if the anti-freeze protection is less than ideal; the worst that happens is the fluid "slushes up".
That's NOT good, as the engine may overheat due to poor circulation, but there is little risk in cracking a block etc.
/ Extreme cold
That is very good to know - thanks!
/ Extreme cold
Gonna be 15 below tonight. That’s why i am concerned
/ Extreme cold #14
I personally would test the coolant before I would plug them in 24/7 with no planned starting.
The refractometers are very precise, and not that expensive.
/ Extreme cold #15
Oh!
When the forecast is for cold, I make the rounds with the battery maintainer to be sure all the seldom used batteries are UP.
And put the trickle charger on the tractor I'm sure to be needing when the snow falls heavy and the temps are single didgit!
/ Extreme cold #16
Overcast
-24°F
-31°C
Humidity64%
Wind SpeedNW 13 G 21 mph
Barometer30.34 in (1032.5 mb)
Dewpoint-32°F (-36°C)
Visibility8.00 mi
Wind Chill-49°F (-45°C)
Last update22 Jan 6:54 pm CST
Currently, Predicted to get worse by another 10 degrees, and not concerned, but not starting any thing but my trucks.
/ Extreme cold #17
Cold is when the coolant in your ancient VW freezes!
/ Extreme cold #18
I did the same years ago, except that I KNEW that I didn't have enough antifreeze. I don't remember the circumstances but for some reason couldn't adjust it and was gone for a couple of weeks, so just left it plugged in. The down side is that if the power had gone out I would have cracked the block.
/ Extreme cold #19
Wind chill is immaterial for something residing at air temperature. 50% AF would be marginal/risky for -44F. 60% would be safe.
/ Extreme cold
Overcast
-24°F
-31°C
Humidity64%
Visibility8.00 mi
You win
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
8' DISC HARROW (A60430)
8' DISC HARROW...
213102 (A64276)
213102 (A64276)
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
