Extra wire?
/ Extra wire? #1
reb
Central Arizona
YM1500D
Putting my YM1500D back together, I find an extra wire. It goes with the bundle (two other wires) toward the rear end. According to the schematic diagram in the parts manual, there should be two wires there, one to each light on the fenders. The schematic diagram shows three other connections (options, I assume) in dotted lines, but since I can't read Japanese I don't know what they are. Two of them apparently have light bulbs, tho there are none are on my tractor. This wire has a ring style connector on it, so I probably removed it when I took things apart.
Does anyone have any idea what electrical device might be at the rear?
/ Extra wire? #2
Maybe a ground? :confused3:Ring type often used on grounds.
/ Extra wire? #3
What color, and does it carry 12 volts? Where, exactly, does it end?
/ Extra wire?
I traced it until it disappeared in the channel inside a fender, where the wire for the turn signal goes. It does not seem to come out anywhere from there. I guess it could have been added by a previous owner for some now unused function. I just tied it back out of the way.
/ Extra wire?
Might be. A previous owner might have used it for that. I don't have one on the tractor. There is no switch anywhere.
/ Extra wire? #7
My work light has it['s own switch. That's why I asked if it carries 12 volts, to be turned off/on at the light.
/ Extra wire? #8
the tractors all have that wire whether or not there is a light. I assume mine is hot when the light switch is turned on?
I have a wire in my 2000 fender but have no light
/ Extra wire?
That makes sense. It might have been connected to 12V before I disconnected it. I don't recall--I'm told that the memory is the second thing to go. I forgot what was first.
/ Extra wire? #10
If it has a ring terminal chances are very good that it's an additional ground. Easy to test with a dmm on ohms, should read little to no resistance between it and ground.
/ Extra wire? #12
It seams my 3000 had 2 wires in both fenders as well. One was a warning flasher, the other a running light. Rear lights had 2 elements. If you have the flasher on the light switch, switch to that position, measure 12v between wire and a good ground, will show intermittent. Had lots of electrical problems with that tractor, ( think it was used in water ) cleaning up the ground wires solved most of them.
Chris
/ Extra wire?
It appears the lamps are single element. Only one fender has an extra wire. My best guess is that CLemsonfor had the right idea. Assuming the extra wire was tied to +12v (which I think it might have been), it would make sense that the wire was for a work light.
/ Extra wire?
Think mine is red (don't remember for sure--I'm too lazy to go out and look), but that might be due to overspray when the tractor was brought over here and repainted.
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
Deere 325G (A64126)
Deere 325G (A64126)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
Well Tank (A64127)
Well Tank (A64127)
Kubota L175 Tractor (A62613)
Kubota L175...
