Extra Lights
   / Extra Lights #1
russpfeiffer
L3240
Just received my new 3240 about 6 weeks ago. I am liking it a lot. I need some extra lights on the back and some on the outsides of the bucket.
   / Extra Lights #3
There is an excellent Kubota forum here on TBN. Perhaps you may find answers to your inquires there. :tractor::welcome:
   / Extra Lights #5
There are several threads about putting lights on this model of tractor. You will find several different ways to moung the lights and switches.
   / Extra Lights
I found out today the dealer does sell an auxiliary work light for the back that connects directly to the wiring harness. While looking at this I found there to be nuts welded to the front side of the roll bar on the front side. A person can make some L brackets and hang the lights on there facing forward up high. The only problem I see is they will be behind the operator and may have some glare. There are 2 more outlets in the factory wiring harness also right there on the right side of the seat just in front of the tool box.
   / Extra Lights #7
I am installing LED work lights using the forward mounting holes in the ROPS bracket where it folds. I am also adding a rear LED work light using the factory mounting location behind the seat. They are 1100 lumens each and will work fine with the low output dynamo and straight off a switch without a relay.
I'll post pics and give a subjective report on perceived glare soon.
   / Extra Lights #8
I intend to add my aux lights to the loader mounts. I didn't want them in back of me on the ROPS. My plain is to install a DPDT switch in the headlight circuit. This way I could select the factory headlights or my aux. lights, and I won't need to run another circuit. I'll be able to choose one or the other, but not both at the same time.
Bill
   / Extra Lights #9
I seldom use this tractor at night - at least going forward. This should do it for me. Pictures of the installed lights are below. I'll take some outdoor night time pics soon.
   / Extra Lights #10
Here is a place to find your ROPS mounted light brackets:
www. tractorcabdepot.com, these are what I am looking at for my tractor.
no drilling and get the lights with the built in on/off switch. and Napa sells the lights with the built in switch.
david
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2019 FREIGHTLINER CASCADIA SLEEPER TRUCK (A52577)
2019 FREIGHTLINER...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
