Extra Lights
   / Extra Lights #1
russpfeiffer
L3240
Just received my new 3240 about 6 weeks ago. I am liking it a lot. I need some extra lights on the back and some on the outsides of the bucket.
   / Extra Lights #3
There is an excellent Kubota forum here on TBN. Perhaps you may find answers to your inquires there. :tractor::welcome:
   / Extra Lights #5
There are several threads about putting lights on this model of tractor. You will find several different ways to moung the lights and switches.
   / Extra Lights
I found out today the dealer does sell an auxiliary work light for the back that connects directly to the wiring harness. While looking at this I found there to be nuts welded to the front side of the roll bar on the front side. A person can make some L brackets and hang the lights on there facing forward up high. The only problem I see is they will be behind the operator and may have some glare. There are 2 more outlets in the factory wiring harness also right there on the right side of the seat just in front of the tool box.
   / Extra Lights #7
I am installing LED work lights using the forward mounting holes in the ROPS bracket where it folds. I am also adding a rear LED work light using the factory mounting location behind the seat. They are 1100 lumens each and will work fine with the low output dynamo and straight off a switch without a relay.
I'll post pics and give a subjective report on perceived glare soon.
   / Extra Lights #8
I intend to add my aux lights to the loader mounts. I didn't want them in back of me on the ROPS. My plain is to install a DPDT switch in the headlight circuit. This way I could select the factory headlights or my aux. lights, and I won't need to run another circuit. I'll be able to choose one or the other, but not both at the same time.
Bill
   / Extra Lights #9
I seldom use this tractor at night - at least going forward. This should do it for me. Pictures of the installed lights are below. I'll take some outdoor night time pics soon.
   / Extra Lights #10
Here is a place to find your ROPS mounted light brackets:
www. tractorcabdepot.com, these are what I am looking at for my tractor.
no drilling and get the lights with the built in on/off switch. and Napa sells the lights with the built in switch.
david
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
