Evolution Metal cutting saw blade replacement.
/ Evolution Metal cutting saw blade replacement. #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
The blade on my Evolution 380 has a number of chipped carbide teeth and several that are missing. So it looks like it's time to replace it. It looks like several choices. Does anyone have an opinion on which blade is worth getting. For the most part I only cut thicker steel. Is it worth getting the 15" blade even if I've never had anything that the 14" was too small to cut? Maybe allowing the teeth to cool a little more because of the larger diameter?
/ Evolution Metal cutting saw blade replacement. #2
I don't have a production shop so don't go through a bunch of blades but since I'm frugal I pay attention to longevity. Smaller blade decreases speed of blade and resistance on motor. That has lead me to apply a little more pressure which has worked well. Eventhough blade speed is slower,less time lapses between when teeth on small blade engage material which effects cooling. Experimenting with running water on blades made them last longer so if I plan several successive cuts I try having water on blade which might be a garden sprayer in a pinch. I usually get what i pay for out of blades and don't have a favorite brand.
/ Evolution Metal cutting saw blade replacement. #3
Depending on how old the blade is usually chipped or missing teeth indicate crowding or applying too much pressure when cutting. Also important to have metal firmly clamped. Any chatter when cutting knocks off teeth. If you stop cutting before the blade gets too dull the blade can be sharpened. Extending the useful life up to 3 times.
/ Evolution Metal cutting saw blade replacement. #4
To fast a feed rate will also kill a blade. Like xr said thin material must be well supported so you don't pinch the kerf. That will pop the teeth right off. I use stick wax for lube seems to help the blade last longer. Diablo steel demons have served me well. 🍻
/ Evolution Metal cutting saw blade replacement. #5
I've been pleased with my do-all penetrator blades for cutting steels and aluminum
/ Evolution Metal cutting saw blade replacement. #6
I've only changed mine once so far on the small saw and I just got another from evolution.
/ Evolution Metal cutting saw blade replacement. #8
I would stay with recommended size recommended by manufacturer ... Larger diameter may increase FPM (feet per minute) of cutting blade and may not be to your advantage....
14" is the standard size while 15" is an optional size. But I think only Evolution makes a blade that size.
I think the chipped teeth happened from cutting thin metal. Even when new the blade seems to throw off sparks so I put almost no pressure on the blade.
This guy does some great comparisons.
I would like to have seen the teeth on each blade after the last test. I was surprised how many blades showed signs of chipping after such short use. I was leaning towards getting another Evolution blade but the Diablo was also on my list. In part because they are made in japan and Italy. Diablo is Freud's cheaper brand so I was a little leery of it. But the last time he showed the teeth and the Evolution was already showing signs of chipping yet the Diablo didn't I'm now leaning towards trying it.
/ Evolution Metal cutting saw blade replacement. #11
Actually Diablo is NOT Freud's cheaper brand; Avanti is - I've had nothing but good results from ANY Diablo product, HD was out of the Diablo version of a 7" metal cutting blade a few years back, so bought the Avanti - 3 or 4 cuts and the blade was TOAST. "Fool me once"... Steve
I have the Evo 380 saw as well, still on the original blade - their claim of how many cuts on square tube is based on using the (included) V block and fairly firm pressure; I had to do a couple mods to my saw's vise so that 90* cuts actually WERE 90's (in BOTH axis) when using the V block.
If cutting other angles, you can't use the V block tho - best you can do in that case is keep the vise tight and cutting pressure "firm"...
/ Evolution Metal cutting saw blade replacement. #12
Give the people at Ridge Carbide a call and ask about the cost to regrind and replace missing teeth. They do all my regrind and sharpening work fo my machine shop and my woodshop. I've bought their saw blades and they are great.
/ Evolution Metal cutting saw blade replacement. #14
The 90 tooth diabolo has performed and lasted well.
The original fein blade gave long life and dulled slightly after cutting some SS tubing. No damage and resharpenable.
/ Evolution Metal cutting saw blade replacement. #15
Project Farmer, Love that guy's testing!! He makes great videos with unbiased testing. Diablo makes a lot of great cutting blades, cost more than some but typically out performs most.
2022 EZ-GO ELITE...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
2022 RBR Venturi 430 High-Capacity Pneumatic Applicator (A63688)
2022 RBR Venturi...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2022 EZ-GO ELITE...
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
