Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #721
Ted - I just bought an LS XJ2025H that I am having delivered in a couple weeks. I plan on getting the following attachments. and would like your recommendation for which of your products to order for this size tractor.
Pallet Forks
Grapple
Post Hole Digger 9" Auger
Jim
/ Everything Attachments #722
Oh man Ted! I like that decal. Too bad the disc harrow you guys just made for me doesn't have one!!
/ Everything Attachments #723
There probably wasn't a good place on the harrow to stick it, but if you'll PM your name, address and phone number to me, I'll be glad to mail you a couple!
Travis
/ Everything Attachments #724
Pallet Forks
Grapple
Jim
Jim, will you have a universal quick attach bucket? If you're not sure, check with the dealer.
If it's an option, I STRONGLY recommend it.
Let me know and i'll recommend the forks and grapple.
As far as the PHD, you'll have the most lifting ability if you use our Land Shark Compact PHD.
You can hook up and use our EA PHD for Compact Tractors, but you'll not have as much lifting ability. The hoop is taller and the boom is longer on the EA, so the auger is further away.
Travis
/ Everything Attachments #726
/ Everything Attachments #727
Check out our new Land Shark Land Plane with ripper shanks for compact tractors, which is available in 48", 60" and 72" widths.
It is the perfect attachment for gravel road, dirt road, driveway and parking lot maintenance.
Premium US Made attachment features:
US Made adjustable cutting edges.
US Made adjustable ripper shanks.
Bolt-on, replaceable skid shoes.
Category 1 Quick Hitch compatible.
Free Shipping to a staffed commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
Click the link to see the special introductory offer: Land Shark Land Plane with Ripper Shanks
/ Everything Attachments #728
Ted, I am new tractor owner and your video's with Peanut are so helpful. Thanks for taking the time to help people like me out! I am looking at a post hole digger with 6-8" auger that would best fit my Mahindra 2538 HST. What do you suggest? So glad you joined the group. Welcome oh brother from another mother! :) I am ready to place an order with delivery to Texas.
/ Everything Attachments #729
Thanks for dropping in!
For the 2538, I recommend our EA 6900 PHD or the EA 6900HD PHD. The HD version simply has a larger gearbox and is rated for up to an 18" auger vs. the 6900, which is rated for up to a 12" auger.
Additional augers can be purchased separately here: Replacement Auger Bits For ETA Brand Tractor Post Hole Augers
Free shipping to your home within 1,000 miles of Newton, NC via Fed Ex Ground.
Travis
/ Everything Attachments #730
I had one of their augers delivered down here.
Truly an awesome piece.
Over built, just like Ted says.
Their brush cutters are the same manufacturing quality.
If you want cheap, that's exactly what you'll get and be replacing it in short time.
Get the good stuff, the first time around and never look back
/ Everything Attachments #731
Thanks Maxify!
Yes, quality is very important to us. Cost, not so much, but VALUE is key!
Here is a video with Ted & Peanut showing the different size PHDs we make.
Travis
/ Everything Attachments #733
What size Bush hog do you recommend for a John Deere 5055e? Does it come pre assembled?
Most would put an 84"+ mower on that tractor. 72" will work if you do not have much acreage, or if you're going to be in tight spots for maneuverability.
72" is the largest we make, and it does come pre assembled. We tested it with a juiced up TL90 New Holland.
72" EA Brush Cutter with 75hp Gearbox & Slip Clutch
Travis
/ Everything Attachments #735
Does the 72" have a stump jumper on it? Also what size grapple should I get for the John Deere 5055e?
Yes it does.
My favorite grapple for the 5000 series is our Wicked Grapple for large compact and utility tractors.
We offer it with Universal Skid Steer Quick Attach, John Deere Quick Attach and Euro Global Quick Attach.
Single Lid
Double Lid
Width is really personal preference as much as anything, but I like 55". You'll be able to get around in and around the woods easier with a narrow grapple.
Travis
/ Everything Attachments #736
Travis, Are you still supplying the pioneer disconnects on your stuff? I got a grapple from you with them on it 2 years ago and i dont use it but a couple times per year and im on my second female part due to leaks. Anyone else have an issue?
+1 here on my Compact wicked grapple. One of the females has always leaked slightly. I plug them together.
/ Everything Attachments #737
Pioneer o-rings: If it's the mating o-ring I like the "X-profile" o-rings at McMaster. I think the size is -211 for a 1/2" coupler and it can be replaced in the field. I've also replaced poppet o-rings by disassembling the couplers. If the coupling rotates under pressure it will likely shear the o-rings and leak. Arrange your hoses so they flex in a single plane instead of twisting as the implement moves.
McMaster-Carr
/ Everything Attachments #740
All my research on disc harrows kept coming back to you for the quality and features, so we just ordered the XTreme Duty disc from you today and looking forward to it (and the new tractor) to come in. When it does i'll post some pics or video of some Cherokee silt loam being worked!
Status
2008 Nissan Xterra SUV (A64557)
2008 Nissan Xterra...
Woodsman 332 T/A Towable Brush Chipper (A64194)
Woodsman 332 T/A...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2025 Wolverine PT-16-02C Class 2 Three Point Hitch Skid Steer Attachment (A64553)
2025 Wolverine...
2437 (A65640)
2437 (A65640)
2003 40ft. Proclaim T/A Vacuum Tank Trailer (A64194)
2003 40ft...
