Everything Attachments
Status
Not open for further replies.
/ Everything Attachments #441
I looked at the holes again today. It could be what I am seeing is the holes in the bracket having been enlarged by the arms coming loose and the bolts gouging up the holes a bit.
Bottom line is for me the bolts/nuts aren't holding the bracket in place well enough. I'll was hoping you had some suggestion how to make it work.
I'll try to come up with a longer bolt maybe and try star washers and double nuts. I took the gauge wheel arms off until I can find a way to keep them in place.
/ Everything Attachments #442
After I confirmed that the hole diameters were supposed to match, I requested pics so we could see exactly what was happening. Pictures are generally worth much more than words.
Since you've discovered that the holes are enlarged, probably from being too loose, I think that the best fix is to drill the holes to match and put the proper size bolt in for a snug fit.
If the holes are the same size and the bolts are tight to prevent movement, everything should stay secure and prevent future issues.
I hope this helps. Feel free to give me a call if you have anymore questions.
Travis
/ Everything Attachments #443
Travis called and put Ted on this morning. He's going to send me some different fastners to try.
Thanks guys.
/ Everything Attachments #444
/ Everything Attachments #445
You must not have gotten as much rain today as Fort Wayne received, if you were able to grade your driveway
We were getting dumped on most of the day
Is that a 3 inch square tube for the scarifiers?
Wonder how thick the walls are on it?
Looks like a well built boxblade!
/ Everything Attachments #446
Lilranch, I am in Columbia City so it did rain all day so not really a good time to grade the driveway. But I have been putting it off waiting on this thing so anything is better than it was.
From the site on the blade:
3/8" thick tube, and hitch.
17" side plates of 1/2" thick steel (!)
1/4" thick curved back.
It is a beast. It was also tricky to get off the truck because the end was at the end of the truck and I only have 42" forks. I could only slightly get past the middle of the thing to lift it.
/ Everything Attachments #447
Thanks for sharing the pics!
You're set-up for some serious play, ummmm work, now!!!
Travis
/ Everything Attachments #448
Here is a video of our new Mitsubishi Laser being delivered. It should be up and running next week!!
Travis
/ Everything Attachments #449
I received the 72" Wicked Root Grapple this evening. Since it is my birthday, good timing, Everything Attachments. In the dark it looks like I should add some welds to the sistered front tines since at least one of them isn't laying flush with the main support and i have a concern about one day hitting a rock and folding it over.
On inspection in the daylight, the weld you have are strong. It just looks like the material moved when it was welded. Slow down and use two clamps for the next guy. You can get your time back by speeding up in the paint booth to avoid the runs.
/ Everything Attachments #451
i have a older model clipper 400 bushhog and i have a few questions i hope you will take the time to answer.first,i raised the bushhog and the blades were straight out,just like a regular lawnmower and when i tried to move them,they would not move.i thought they weresupposed to swing like other bushhog blades so when you hit something it would not break the machine.can you tell me what you think the problem is?secondly,i have a leak on my lower gearbox for my bushhog.i noticed it had a bearing around the shaft.if i took all the bolts off,would it fall apart?and is there a gasket to replace the one that went in there?i thank you for your time and i hope you can answer my question because i love this bushhog and want to keep it in the best shape i can,thank you.i am new to this forum stuff so i hope i did it right.
/ Everything Attachments #452
/ Everything Attachments #453
It sounds like the blades may be seized to the bolts or the blade holder. You could try using a good penetrating oil to break them free. If that doesn’t work, I’d loosen the bolts, clean the surfaces and re-torque. If the blades are in bad shape, it’d be a good idea to go ahead and replace the blades/bolts while you’re at it.
The leak sounds like a seal on the output shaft. If you remove the blade holder(stump jumper) from the output shaft and remove the bolts from the top of the deck that hold the gearbox on, you can take the gearbox off and replace the seal.
I hope this helps.
Travis
/ Everything Attachments #454
I was born into the Baby Boomer generation. When I was growing up it was important that businesses took care of their customers because, if they did not, they did not stay in business. Companies today are driven increasingly by what makes the CXX the biggest bonuses on a quarterly basis. The future of the company is of no consequence because they do not plan on being there anyway. As consumers, we are just a necessary evil to keep their revenues flowing. Today, the commonplace corporate motto is: "If it wasn't for all of these damned customers, we could get some real work done around here."
Now having shared my sentiments toward corporate America, I want to share my perceptions of Everything Attachments. I recently ordered a 72" Wicked Root Grapple, a Post Hole Digger and a Subsoiler from them. I will limit this review to how I was treated as a customer, and, in the future, I will write reviews on how well these attachments perform in the field.
The transaction was flawless. They shipped my equipment in the fashion that I requested since I did not want to make multiple trips to the freight terminal 100 miles away. The one thing that impressed me the most was the way in which they communicated. In the past, if I got a nickle for everytime I was promised a return phone call that day by a company, and never heard from them, I could probably afford to buy Everything Attachments from Ted if he wished to sell. I must say that Rick, Travis, Greg and Scott communicated exactly as they promised everytime.
I have a Mahindra 5035 PST on which I am using this equipment. When I mounted the post hole digger the tip of the auger would barely clear the ground. When I spoke with Travis about this, I learned that I should have about 6 inches ground clearance. After sending some photos for them to review, they made up a new hoop for me that was 3 inches taller than the standard one initially shipped. Now I have excellent ground clearance, and I am a happy customer. This is the kind of service that makes you want to do business with them again. They wanted me to be happy with their product, and they helped me solve the problem I was having. I will buy from them again. Now, if I could only get Mahindra to sign up...............
/ Everything Attachments #455
I have read a lot of great comments about Everything Attachments over the past two years. I have been impressed. It is not often you hear and read of great customer support and quality.
Last Wed. I decided to to bite the bullet and order the post hole digger I have been wanting for months. I called at 9:30AM and after a brief discussion I decided on the 6900 model with a 9" auger. I placed the order and that was that.
At 10:20 AM I received my e-mail verification of the order and tracking numbers. WOW, that was fast.
At 10:45 AM on Thursday, Fedex delivered my digger.
Now, I realize that I only live 160 miles away from their facilities, but this was unreal service.
Thank you Ted and crew.
One very satisfied customer,
Jack Terpack
/ Everything Attachments #456
I want to thank Everything Attachment for the professional and prompt service. I called on Friday afternoon and talked to Travis about buying a set of pallet forks for my tractor. I placed the order and the following Thursday afternoon I picked them up at the terminal in Beaumont, Texas. Just outstanding!
/ Everything Attachments #457
Thanks guys for the business and for your kind words!!
Our customers are #1 :thumbsup:
Travis
/ Everything Attachments #458
Last week I emailed Rick a few times back and forth discussing skid steer mounted hydraulic augers.
He pointed me to a McMillen x975. I placed the order Monday AM and it showed up Thursday noon-ish!!
great customer service and quick shipping. It looks like it got a few blemishes during shipment, not to bad. I am currently installing a jumper from my remotes to FEL and I hope to punch my first hole this afternoon :)
Thanks again Y'all!!
/ Everything Attachments #459
Thanks for the business!
That is a great PHD that should give you many years of excellent service!
Travis
/ Everything Attachments #460
Hello,
I am in the process of looking to purchase a 60" rotary cutter. My research came down to the Landpride RB1860 or the Woods BB60X. I had a post going on TBN and I was given the EverythingAttachments website to look at their 60" unit. I must say that the video of the unit was impressive. It has a strong gearbox (up to 75HP), slip clutch, strong deck (10 gauge steel) etc. It seems to have everything that the Woods or Landpride units have except the user data to support it's functionality. Has anyone purchased this rotary cutter and posted their input on how well it works in the field. From what I have read about the company, their reputation is going in the right direction but it's still difficult to purchase something without some backgroung to support the equipment. It is priced more reasonable than either the Woods or Landpride and that is certainly a very big consideration.
Any feedback on the EverythinAttachments 60" rotary cutter would be very helpful.
Status
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2016 KENWORTH T680...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2017 Ford F-150...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
