Everything Attachments Wicked Grapple Build
Status
Not open for further replies.
/ Everything Attachments Wicked Grapple Build #161
Roger check the chemical makeup of your enamel paint from the Kub Dealer. MOST of the standard Enamels can use a standard hardener additive. take the can into the local TSC store and compare the chemical makeup to their store line. Also the stuff they have tor tractor/implement paint at TSC is actually pretty good and very reasonable. I'll include a pic of my Dump Trailer I built in 02 and painted it over bare WELL PHOSPHATE treated steel. It has very little rust and has hauled probably 200" ton of wet creek scraped up gravel. It has rust in the bed where dumping scraped off the paint and wood/wood chips sat in it keeping it too wet letting it rust.
I MAY even sand down the bed & give it a 2nd coat of paint this year if I'm still off work as it would be a cheap repair/fix.
Mark
/ Everything Attachments Wicked Grapple Build #162
Isocyanate fumes will go thru most charcoal filters. The only approved way of paint with it is supplied air. i was an aircraft painter for an airline for 2 years. Even in a booth with moving, filtered air we had to wear supplied air. Most of the paint we used was polyurethane and epoxy from PPG and Akzo Nobel.. out in the Heavy Maint. hanger we could not spray. We used rollers and brushes...and had large 3 ft fans blowing when we were painting in the fuselage.
Plus, when we applied Corrosion preventative coatings, That stuff we used was nasty, Worse than the Paint...
/ Everything Attachments Wicked Grapple Build #163
You may want to weld some mesh on the back of your grapple to protect your tractor when ramming into brush.
/ Everything Attachments Wicked Grapple Build #164
Sorry, but false. Eventually all organics will breakthrough a carbon cartridge when saturated. They all have different rates that it happens at. The real problem with isocyanates is that you can't smell them very well, so the risk is you get exposed without knowing it. Technical term is "poor warning properties" - it is toxic in lower concentrations than you can smell it. That is why supplied air is required. It is nasty stuff, but exposure amount matters a lot.
A lot of hardeners for enamels are isocyanate, too. The concentration is low enough that a carbon cartridge is ok for home use (short exposures with good ventilation), but that would not pass muster industrially. For full 2k urethanes, I would think long and hard before using a carbon cartridge...
Nothing is ever as simple as it seems....
Mark
I know I have some TSC valspar paint, and maybe some hardner. I know I have some other stuff like some limco. I have not checked any of it yet.
I was thinking about adding some expanded metal to the grill guard on the tractor.
Getting ready to weld.
I got the top of the pipe welded tonight, the bottom still needs to be welded.
Close up.
/ Everything Attachments Wicked Grapple Build #167
Do it! If you do any brush work, it will payback big-time! 3/4" x #9 exoanwd, flattened is commonly found and a good size. Far easier to weld in with a mig or even tig over stick.
Something like that would defiantly get migged.
Doing a little work on the grapple and I took a pic with my thermal imaging camera.
The tines are completely welded to the pipe.
End caps are on.
Some of Toothed Gussets are ready to be tacked.
Now they are all welded on, I still need to knock some slag off of the welds.
It is looking more like a grapple all the time.
/ Everything Attachments Wicked Grapple Build #171
I like that tooth gusset concept. My concern before was that if the teeth are made from a higher strength alloy, welding the pipe thru them may anneal and weaken them in the highest stressed area. The gussets should take care of that concern.
The lids are all welded up and ready for the top and bottom guard to be welded to them.
The lids on the grapple.
/ Everything Attachments Wicked Grapple Build #173
I know nothing about welding Roger, but I've built a bunch of stuff...nice, clean work man. :thumbsup:
Thanks Jay.
/ Everything Attachments Wicked Grapple Build #175
Looks like a nice kit and you're doing a good job on it. A kit with pre-cut pieces is a good idea. I built a little different style of grapple a couple of years ago and it was very time consuming cutting everything with a torch. It didn't turn out too bad for my first major project but it looks like laser cutting makes all the difference.
Thanks. The quality of the kit is top notch.
Cylinder mount welded on and getting ready to weld the bottom lid guard.
One complete lid assembly installed
One partial lid assembly
View of both, also the cylinder mounts were welded on the grapple
Here is a pic of some of the welding rods and slag (the dust pan is 12")
/ Everything Attachments Wicked Grapple Build #178
The grapple is looking great, I can sympathize with the amount of welding having just finished fabrication of a 48" wide of my own design. I went through nearly of full tank of gas for the mig and about 6 lbs of wire I think. Then there is the painting and hydraulics yet to come for me. I need to make some mounts for the diverter valve and the quick connects today; then figure out the hose lengths and the endless puzzle of fittings.
Once again, great job on this project and the documentation of the progress should give others an idea of the amount of work involved.
Dan
/ Everything Attachments Wicked Grapple Build #179
Roger, first, fantastic build and documentation, second, would you come to Louisiana and build one for me ? :D :drink: I'll feed you mud bugs (crawdads) and cold beverages 'till you grow claws ! Lololol ! Seriously, very nice work and I very much look forward to seeing the final product on your machine, perhaps a video of the final product in action ? Thanks for this thread...
Rich
/ Everything Attachments Wicked Grapple Build #180
Dan
Do you have any pictures, of your project? you should start a thread also.
Dave
Status
2017 International HX620 Quint Dump (A62613)
2017 International...
2006 Isuzu NPR Box Truck, VIN # JALB4B16567020383 (A65563)
2006 Isuzu NPR Box...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
