Everything Attachments Wicked Grapple Build
Status
Not open for further replies.
/ Everything Attachments Wicked Grapple Build #221
Why do they cut so many holes from the steel ? Looks like it would weaken the lower grapple. I know it takes some of the weight off but if the tractor can't handle the extra twenty or so pounds they removed it is too large for the machine. For a 72" grapple one would need the weight and power of an 80 hp tractor. Less than 55hp would severely limit production.
Shipping the steel is going to be costly. The real gain for the kit is the water jet cut arched pieces which could be ordered locally. I don't think production figures will be very high for these kits.
On the PAINT did ya do a scratch test just to see how well it worked? I'm sure it will be better than un-hardened paint no matter. Drying correctly was biggest concern without wrinkling or burning the paint (drying too fast or causing chemical makeup problems.)
Mark
The paint looks fine. I took a pick and scratch tested it. I could run it across lightly and it would not hurt the paint but if I pushed with some pressure it would dig in.
They saved 90lbs with their grapple design. They used a steel with a minimum yield strength of 80, 000lbs.
/ Everything Attachments Wicked Grapple Build #223
Maybe not the kits, but they have sold several grapples to TBN members already.
http://www.tractorbynet.com/forums/attachments/267492-wicked-root-debris-grapple.html
Everything Attachments | Skid Steer Attachments, Tractor Attachments, 3 Point Hitch Attachments, and Farm Tractor Implements.
/ Everything Attachments Wicked Grapple Build #224
Expensive engineering. Blasting a start hole to laser cut all those holes takes 50% of the machine time, if you can cut 10 inch per second at a given material thickness, blasting a start hole to begin cutting a hole takes about 5 seconds of pre-heating before you can actually start cutting.
The grapple would be cheaper without the holes. The cut out pieces cant be used for anything else so they're payd for anyways, so its cheaper save expensive laser machine time by leaving them in place :)
/ Everything Attachments Wicked Grapple Build #225
You are right but the LCF would be way down!
/ Everything Attachments Wicked Grapple Build #226
You are right but...
It would affect the LCF!
/ Everything Attachments Wicked Grapple Build #228
90lbs is a significant amount of weight on any compact tractor, often 5-10% of capacity. It opens up the operating window in a real and tangible way. The cost of making those holes is no doubt covered by the savings in shipping costs, a few pounds of metal saved can mean staying in a lower weight classification meaning more and cheaper shipping options. Maybe they are just to look cool, but they are common enough on all sorts of equipment that I'll bet there is more to them that.
Mr. HE:cool:
/ Everything Attachments Wicked Grapple Build #229
Mr. HE:cool:
They are just that cool looking, reduces weight without much if any reduced support due to the ladder design everything self supports it's neighbor tine and stiffens everything up once it is all welded.
If you bend it after welding, more than likely would have STILL bent it had it been solid. One bad thing is there will be more chances for sticks and such to wedge in them. welding in light gauge sheet metal would help out that aspect & making a template from cardboard could be easy & only add a couple lbs where as removing the thick metal shaved of probably that 90+/- lbs.
Mark
/ Everything Attachments Wicked Grapple Build #230
It is hard to believe they lose 90# by drilling holes and using some high tensel strength material. Without seeing one in person it is hard for the brain to capture this. The only thing I know about the high strength steel is once it is bent..... good luck ever returning it to the original form. I hope it works out great. I like to putter in my shop so I will design one I can live with. I prefer tube steel as it is readily available and easy to work with. I can segment angles and get any shape I desire simply by turning the Ellis band saw head. Creative new designs appear quite often. I know there is a grapple hidden in my steel pile. Just have to sort out the pieces.
/ Everything Attachments Wicked Grapple Build #233
Is it painted yet?
/ Everything Attachments Wicked Grapple Build #236
Laser leaves a burnt edge while water-jet the edge will not be as straight in thick stuff and will be totally smooth & raw/clean steel no blackened edges almost polished look.
If you are welding on a edge that was cut the laser cut should be ground to remove the heat hardened/oxidized edge while water-jet will be ready off the machine (other than wet.)
Water-Jets can make holes a bit faster in heavy/thick stuff for most part I do believe too. though the edge no longer is perpendicular to plane.
Mark
/ Everything Attachments Wicked Grapple Build #237
I think they use a laser.
No, I have not had a chance to get back to it. Plus now somebody talked me into adding expanded metal.
Sorry about that but I think you will agree its a good idea, That's the way mine came from MIE and it was even painted orange and black.
I got the lids cleaned up and primed. I also primed the pins for the lids, just the ends.
Mark
This has a pretty smooth edge.
Yeah, it is a good idea. I got to thinking if I was loading over a truck and or lifting high something could fall out of the back of the grapple and on to the tractor. I guess something could still fall out of the bottom and possibly hit the tractor but it would be a pretty low chance at doing that. I still may add some expanded metal to the grill guard. I am going to get some and cover the bottom of the BX too.
I check my test paint and it seems to be pretty durable since it has sat a while. It is not good weather for paint drying.
Here are the Lids primed. I cheeped out and used red oxide primer. I was going to use some dupont primer but I figured it was not worth the extra money because it is going to get scratched off.
I made a template for the expanded metal.
I laid it across a 2x4 to cut it height wise then clamped it to a welding table and cut the width.
I got a few welded on. I ran out of cut off wheels. I almost finished cutting another one out.
If things go right I am hoping to have it primed tomorrow.
I almost forgot to post my pics tonight.
I did not have enought time to get it primed but all the expanded metal is welded in. I cut everypeice to fit between the tines.
Status
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
