Everlast 200 Stick review.. Kinda
/ Everlast 200 Stick review.. Kinda #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, So I called mark seeking a plasma cutter. At the end of the day he had sold me on a 40 plasma, and a 200 Stick. Just so it has been said, he has jammed me up with the wife something fierce.
So the thing to know is that I am not a welder. I am a guy who applies heat two pieces of metal with some sort of box and a glowing stick and if it holds, I consider myself fortunate. I have had no training, and have been told repeatedly that my welds look like a parkinsons patients hard work. Take what I say with, well it is my opinion and i think it counts, but it is just my opinion.
As for my gear, I have a lincoln tombstone that was used when I got it and I loved it. I got a Lincoln 180C last year and love it. But I am not very good at either.
So today one box arrived. Much quicker than I thought it would. Looks like it shipped from SFO. It was my 200 stick. I would say that my only complaint here,and it is a good thing for Mark, is that stock seems to be an issue. They seem to be selling lots of product, upside, but my Plasma is back ordered, downside. Not a huge complaint, but a bit of a bummer.
I unpacked the box. Not much to report. Leads, clamps. usual stuff that looks comparable to the other sticks i have seen. One big plus was the inclusion of a 110V adapter. I was planning to make one myself and the cost would have been upwards of $50. First thing I noticed is that it is really, really, really small Now I have been lugging my Lincoln for 7 years. Its a friggin beast. And the 180c, while not a Miller 252, has some weight with the big spools. Small makes me nervous. Just being honest. I think of 240 volts being converted into something magical and wonder about the cooling. But if I were to strip out my 180C it would probably be the same when you break it down weight and size wise. I think I am just being overly concerned on this issue. Manual is thin. I think a bit too thin. In giving 2 cents when no one asked for it, Everlast probably sells a lot to the beginning to middle grade welder. They don't take into consideration the guy looking at this and going WTF. The manual doesn't really cover much.
So anyway, I have three more complaints about the machine but will get to them shortly. I plugged in cables, Clamp on positive, Stick holder on Negative. Plugged the machine in and looked for the on off switch. Well the on off is a breaker on the back of the machine. I have to say I am thrown by this. First being a breaker but second there is a switch on the front that looks like an on/off switch and it is really just a switch for Tig / Stick. I dunno. I kinda want the on off on the front. I know my Lincoln is on teh back, but I attributed it as a way to remind you to get the gas. Anyway, Grabbed up some 1/8 6011, set the machine to 100 and struck the arc. OK, I am not kidding here, It was amazing for a moron like me. It struck, it didn't stick, it was way way way way cool. Right then I decided that my Lincoln was going on craigslist.
So I am not going to comment on the weld itself. There is too much I do not know about welding to give any rational review. I will say this, however. I had the leads backwards. Everything splattered. I was welding on 1/8 Scrap. Angle Iron. I had a **** of a time not melting through the metal. I turned the machine down much lower and got the leads worked out and the 6011 was OK. not pretty, very messy. After burning a rod I went and grabbed my "stash" these are 1/8 rods with three green markings on them. I got them from my uncle. I have no idea (I assume 7014 or 7018 but I do not know). All I know is that they burn different. I would say smooth. Well, putting them on this machine was really great. I was so very very impressed. Still melting through the 1/8 a bit but I can see how I could become a much better welder with this machine.
So I am very happy with this purchase. very, very happy. But it has forced me to call on of my neighbors who welds semi professionally. I am building a stump grinder and will take the metal to him and have him supervise and teach me while I weld it together.
Oh,,, my other complaints. On my lincoln there is a welding chart sticker. I know, if you are a pro it is a waste of time, but for beginners, it would be nice to grab a rod, be able to size it, and be told what range to put the machine in. Third, the strap. I really hate something dangling around the machine. I know this saves money but a hard carrying handle would be better in my mind. They provide you with an over the shoulder nylon web carrying strap. I think it is going to be coming off. Finally shutting the machine down freaks me out. Will ask mark about this. but when you turn the breaker off the fan runs a moment longer, then the lights on the front start flashing. I assume this is capacitors releasing energy but I need to check.
I look forward to your guys suggestions.
/ Everlast 200 Stick review.. Kinda #2
Normal for the fan to run on. Just like you figured, capacitors discharging.
The switch is on the back so there is a minimum of unswitched wires inside the case. Need to do it that way to get certain kinds of certifications in some countries.
That is a great machine BTW.
I'm going to add a handle to mine too.
/ Everlast 200 Stick review.. Kinda #3
Honest, and kind of cute, review.
I, too, have the PA 200 after coming from a Lincoln buzz box. It is quite a transformation, not only in size, but in arc quality. Practice will be a lot more fun if that is what you intend to do.
I mark my rod holders with a label telling the size and recommended amp range for the particular rod. The plastic rod holders are available from Harbor Freight for cheap.
This Miller stick welding calculator will help make the rod choices: Miller - Stick Welding Calculator
Also, the Everlast website has more complete manuals for particular machines: Tig Welding | Mig Welding | Plasma Welding
The PA 200 has an automatic hot start. That feature allows rods to light much easier and more consistently.
I fell into the Amazon PA 300 trap (thanks to Shield Arc) so the PA 200 is retired to the barn. Being so light, it is perfect for mobile repairs with a large Honda generator.
/ Everlast 200 Stick review.. Kinda #4
The 200 should have a better manual included, but not the full manual. And there will be a dedicated 200 manual being loaded later this week. Just want to go over it and make sure it is sufficient before it is loaded. We've (I actually) been toying with an idea of creating separate welding primers for people, instead of trying to include them in the manual. The manual includes basic instructions on operation and technique even, but as I've said before....you buy anything else, a tractor say....It tells you what the controls are, but it doesn't tell you how to farm or how to plant, plow or anything in detail. An automobile manufacturer provides an operator's manual with a car, but it doesn't give driving instructions. It gives operation instructions, but not driving instructions. I guess in the same vein we give operating instructions, but not "welding" instructions.
/ Everlast 200 Stick review.. Kinda #5
Plasmas are in...sort of. lol. They are in port, but in customs flagged for "extra" inspections, which I think last I heard they were X-raying the contents of the packages. Should be in today, if not Monday...and that is a PowerPlasma 50 you bought. 10 extra amps...
/ Everlast 200 Stick review.. Kinda #6
Sorry for the separate posting, but just noticed this: You were welding with the wrong polarity. Put the electrode holder over in the + and keep the work clamp in the - or the 6010 (-) port.
That'll smooth things up for you especially on 6010.
Your online manual (and presumably the printed copy but I haven't seen it) you have gives you a chart of basic amp settings. It should also give you polarity settings.
So a whole bunch of things.....
GW Thanks for the links. Will use them
Mark - Yup, it is a 50 i am getting. And sorry I did not make it clear, I caught my error with the wiring (Electrode and ground) and switched it around. In all fairness you informed me of the new manual coming. I will respectfully disagree on the driving correlation. Only that the manuals on my Lincoln discuss welding in some detail. In my opinion, you can sell more of these if you make them less scary. In hollywood we spend a lot of time worrying about our audience. Every business should. I do want to recognize your remark that you are considering more info. Great idea in my opinion.
To everyone. I am really impressed by this machine. Maybe I shouldn't put the machine up too high on a pedestal given my skill set, but the difference between my buzzbox and this machine is night and day. My welding neighbor says to me in the end it does not matter the machine as much as it matters the technician. But i do feel this machine is giving me the opportunity to become a better welder quicker. And given the price point it makes all that much more rational upgrade.
I am pleased as punch with this purchase. Now if I can just figure out how to make the wife as ecstatic as me about the purchase.
/ Everlast 200 Stick review.. Kinda #12
I also have the ST200 and love it, coming from a Lincoln Tombstone AC. I agree the shoulder strap is a pain to say the least, would much rather have a solid carrying handle.
The ease of arc start and auto arc force, for us that can't hold the arc length at the same distance consistently, make this welder a very good over-all welder. More important to me is the ease of use makes it a very nice unit for us novice occasional users.
Like Mark mentioned, for 6010/6011 use the far left connection for the work clamp - makes a world of difference. Actually, I forget to change it back and end up using it that way with 6013 rod and it works pretty good.:laughing: Just did it again this afternoon, seems to make the 6013 penetrate more and less splatter.
So Mark and SS, can you explain two things. Work clamp I assume is the rod clamp? What is the difference on the plug on the left compare to the plug on the right (in laymans terms if possible)?
/ Everlast 200 Stick review.. Kinda #14
Work clamp is the "ground" clamp
So I am a bit embarrassed and owe Mark an apology. As instructed, I downloaded the manual from the internet and was using that as my manual of info. Well, some how the PDF did not download as much as it should have and I got only half the manual. the back half goes into much more detail. It isn't brilliant, but it is not as short sighted as I led everyone to believe.
I will review the manual that came with the machine (I assumed it was the same but TBD).
/ Everlast 200 Stick review.. Kinda #16
I apologize for it not being "brilliant". I am only so smart. :eek: With the 200ST, the plug position of the 6010 port has been changed to accommodate the new internal design and dual voltage capability. The far left port when the work clamp is plugged in there (yes it is also called the ground clamp) is the 6010/6011 (cellulose) port. The new manual that will be posted will show that change. The box manual should reflect that, but it was carved up by the factory without my review until the new one can be written, among my other duties and I haven't seen it. I know the box manual has a couple errors...but no major complaints from customers.
Getting back to the 6010 port. There is a separate, albeit small reactor for the 6010 port which changes the arc quality. It makes it stiffer and more aggressive. You can run the work clamp in the 6010 port and weld 7018, but it is going to be a lot more spattery and should send the flux flying intermittently by popping and spitting.
/ Everlast 200 Stick review.. Kinda #17
OK, to make it simple. There are three places on the bottom of the face of the 200ST (stick/tig) welder to attach the welding leads. Facing the welder:
>The left socket is for 6010 or 6011 rods. It keeps 6010 rods burning better because the electronics ​are slightly different. It is used for the "ground" clamp. AKA "work" clamp.
>The middle lead socket, marked "-", if for the ground clamp. It is also known as the "work" outlet. So one of the two left sockets is for attaching to the piece you are welding - on a bright shiny spot.
>The right socket, marked "+", is for the rod holder and rod (AKA electrode). This is DCEP or Direct Current Electrode Positive. It is also called "reverse polarity".
Now, on the PA 200, which doesn't have the built-in TIG feature, the far left is the work/ground clamp. The middle is the 6010 ground socket, and the far right is the electrode or "stick" socket. Why it has to be different than the 200ST is anybody's guess.
WHEW, with all this technical stuff I'm sure to have something wrong. Mark, Shield Arc, or someone else please check to make sure. I'll edit my post if necessary.
The welder will run with the + and - leads switched around, but there can be penetration and quality issues. I think that if you use TIG then the leads are switched around. I don't do TIG so someone else can address that better.
/ Everlast 200 Stick review.. Kinda #18
FYI; until the new manual is out, download the 14ST manual. it has all the controls and plug connections in same configuration as the 200ST. That's what I did, plus paying attention to what Mark told me when I bought.
Again, everyone great stuff.
GW - Getting the plugin information down. Two questions. Why do they call the clamp the "Work" side? I thought the Rod was doing the work.
Second, what is the TIG switch for, or should I say what does it do?
/ Everlast 200 Stick review.. Kinda #20
The "work" clamp is attached to what is being "worked" on. Welding terminology can be confusing. Weldors are an odd lot in general - not anybody that posts on this forum, of course.:)
The TIG switch probably reverses polarity since TIG is usually run on "straight polarity" - another welding goofy term. There are likely other adjustments that the switch makes as well. Mark would know. Gas shielding also has to be added with TIG. It takes a skill which is foreign to me.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
King Kutter II Tiller for sale.
King Kutter II...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
