Ever last 200st
/ Ever last 200st #21
I need to clarify my statement. It is a TSC is a decent place to shop for certain things. I do buy my stainless brushes from them. Can't find them anywhere else. Those hobart orange handle brushes are tough and you have a couple of different choices. I bought a welding clamp as well from there (F style). But for stick electrodes stored, and handled properly not the best place. For a wide variety of choices for welding gloves, safety glasses, shields, etc... it is not the place I go to.
/ Ever last 200st #22
How does one decide when to bathe their 6011 rods?
/ Ever last 200st #24
When they run erratic, or burn off to one side.
Oh, okay, thanks. I was afraid the only response I would get would be something silly involving dirty children.
/ Ever last 200st #25
I have a MS. Welder supply not to far from me.
I really like Mississippi Welders Supply. They will deal with non-pros without the attitude you sometimes get at trades-specialist shops (at least my local one). Helpful and well-stocked. I like 'em!
/ Ever last 200st
Yeah they are and they don't charge to much for their stuff either .When I go back to work I have to pick up a torch set for my shop.
/ Ever last 200st #27
Mark, while we are on this. What is the difference between the 6010 output and the "normal" Never fully understood that feature. Is it just changing Polarity?
Marks reply is great in a nutshell. If you want to dig deeper, Look up Open Circuit Voltage in Welding. 6010 and 6011 cellulose coated rods require a higher open circuit voltage than the other variety of rods. They are more difficult to keep lit at a reasonable arc length because of the flux.. OCV allows the rod to stay lit better by supplying higher voltage for the cellulose rods. Typically machines with higher OCV have lower duty cycles because of wasted voltage trying to keep the rod lit. The nice thing about having a 6010 port is that you don't have to waste voltage all the time, Only when burning 6010 and 6011 ( I don't like either one really ).. High OCV machines also sometimes require a larger breaker to perform at maximum output. I like the idea of a 6010 port rather than a high OCV continuous.
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
3PT TINE RAKE (A63291)
2019 John Deere 712C Cornhead (A63111)
2019 John Deere...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61572)
2025 X39 Hydraulic...
