Equipment shed.
/ Equipment shed.
/ Equipment shed. #23
Never tried to buy 2x tubing...
Would you know call out for the tubing you used and a ballpark price for a given length.
Metal tends to very expensive in my part of the Bay Area... a lot less manufacturing now.
/ Equipment shed.
2"x4" x 30' tubing runs about $45.50 per joint. 4"x4" x (1/4" wall) x24' runs about $110.00 each.
Post mix sakrete $3.90 per 80# bag.
/ Equipment shed.
A few more framing pics.
Attaching fram to the tail end of the rafters. The top of side metal will attach to this part.
Digging additional holes for more support post.
Building the rest of the main mid-span header.
/ Equipment shed. #26
Appreciate the info... I have a carport that has 3 times suffered wind damage over 37 years... I built it in 1980... get some real strong gusts in the 80+ mph range every blue moon...
/ Equipment shed. #27
I sure like how straight those metal 2x4's are!!!!
/ Equipment shed. #29
Did you do anything special to shore up or stabilize the shipping container it attaches to? I have a 20' container that I could possibly do the same thing with. But it just sits on the ground on top of a few 4x4 treated posts running cross ways.
/ Equipment shed.
I built a pad for it and it sits on crossties and the ties are filled to grade between them. Reason for the pad is so I could get it high enough that I can get the tractor under the shed. The narrow end is to the North and the house protects it from the wind from the south and west. Hardly ever get wind from the east. I depend on the weight to hold it down.
/ Equipment shed.
Some additional framing pictures.
Welding in the rafters. Almost done with that phase of the job.
Here you can see the permanent header. The temp. header has been removed.
Starting to install the horizontal rails (2"x4" tubing)
/ Equipment shed. #32
Thanks for the update!!!! You are making great progress!!
/ Equipment shed.
Here are some pictures of the shed addition as it relates to the surrounding property/buildings.
/ Equipment shed. #34
When the steel super structure is finished does in need a coat of paint or is that overkill?
/ Equipment shed.
You could paint it if you wanted to. It is what we call "red iron" and it will not be exposed to the weather. I am having to work on it as the weather allows me to, cold or windy or both. So, no , I don't plan to paint it.
/ Equipment shed.
Got a little more done on my shed.
/ Equipment shed. #37
Look's real nice Travlitt, those spans makes me jealous living here in snow country.:thumbsup:
We need to build a roof so it sheds snow and has 100#s/f snow load! :laughing:
/ Equipment shed. #38
This looks fantastic. How far apart are the rafters? How do you attach the OSB to them for the roof?
/ Equipment shed.
The rafters are on 2' centers. I attached the OSB to the rafters with 16 self-tapping flat head screws per sheet. About 38 sheets.
/ Equipment shed. #40
Looks a lot bigger then I expected with the siding on. That's going to be nice.
2013 INTERNATIONAL PROSTAR+ 113 (A67714)
2013 INTERNATIONAL...
2019 Yanmar ViO35 Midi Excavator (A66734)
2019 Yanmar ViO35...
2006 GMC T7 4X2 S/A SERVICE TRUCK (A66091)
2006 GMC T7 4X2...
2021 WESTERN STAR 4700 DUMP TRUCK (A67714)
2021 WESTERN STAR...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
