Equipment shed.
/ Equipment shed. #1
travlitt
Platinum Member
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
Getting ready to add 1200 sq. ft. to my equipment shed.
Day 1
Removing trim.
/ Equipment shed. #2
Good Deal...
An equipment shed has got to be one of the best cost wise for keeping equipment in order... looks good.
/ Equipment shed. #3
Looking forward to more pics. Are you using 2x4 metal tubing? I have some of that and it's super heavy. Good thing you have those forks!!!
/ Equipment shed.
Hello Eddy, Yes I am using 2x4 metal tubing. The rafters are 30' long. 2' spacing. I will post pictures as I progress along. It is a slow go working along. Some times I need to be at both ends at the same time.
You and the wife have a great evening.
/ Equipment shed.
More framing.
/ Equipment shed. #6
I like how you hold your framing in the air. When one tractor isn't enough, use 2!!!!!
/ Equipment shed. #7
That's quite a project!! Looks good!!
Did you use 2x4 metal tubing for strength over the span? And what brand/model of forks do you have for the front of your tractor. I need to pick up something like that.
/ Equipment shed.
/ Equipment shed.
Eddie the big tractor is holding the rafters up off of the temp header (wood post with temp header). I am using the little tractor to put in place the permanent steel header. That header is mid-span of the 30' addition I am adding on. The header is made with 1.. 4"x4" x 1/4" sq tubing and 2.. 2"x 4" tubing. Support post are 4"x4" x1/4" tubing set in the ground 3' in a 12" hole with rebar. Each post has 3 or 4 80# bags of sakrete.
Some details of the header I installed.
/ Equipment shed. #11
Nice work. Anxious to see the progress.
I added 600 sq ft to my machine shed last Summer by myself. It's good for the Soul. Bad for the back. :D
/ Equipment shed.
I sure agree on the good for the soul and bad for the back.
My wife is my helper, does a good job.
I will have a total of 2000 SQ. ft when finished.
I will have 2 overhead doors and one walkthrough.
/ Equipment shed.
Additional framing and some construction details.
How the new rafters are attached to the existing shed.
First attached with screws.
Then welded with E 6011 1/8 rod. Be advised, I am not a welder.
/ Equipment shed. #14
Oh wow, you need to take some pics of the whole building. I'm a bit confused about what you did to start the add-on? Remove siding? So you are more than doubling the size of your building? Awesome!!!! :)
/ Equipment shed.
I started out with a 40' shipping container. I built a shed and it was attached to the container. That shed was 20'x40' To start this addition to the existing 20'x40' shed, I had to remove the TRIM on the existing shed, 2 nd picture.
Origional shed. I removed the blue trim.
When I get all finished it will have a total of 2000 Sq. ft and be fully enclosed with 2 overhead doors and 1 walkthrough.
/ Equipment shed. #16
Yep, got it now!! Thanks for the explanation. :)
/ Equipment shed. #17
Did you have it engineered? I'm wondering why the metal spans so close together for just a roof?
/ Equipment shed.
Not engineered. Just me, I always overbuild. Mainly its because the way I had to run the rafters.
/ Equipment shed. #19
How did you attach the rafters to the side of the container? Did you drill through it to attach bolts?
/ Equipment shed.
Like this.
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
(12) Round Bales of Hay (A65640)
(12) Round Bales...
